Upper Radiator Hose Replacement
Usually you unclamp the clamps, replace and fill with coolant
You don't specify if it's a 32 or 40 valve motor. They are different hoses, but it's not hard, check out the procedure on audipages.com for the timing belt replacement.
Re: Usually you unclamp the clamps, replace and fill with coolant
Ok I have a 97 4.2 quatro. I will take a look at that thread. So when I unclamp the clamps then reinsert the new hose will I need to drain the system completely and then refill it or what is the correct procedure for that? Thanks
Just research it on the timing belt change out procedure
If you don't know the answer to the question....I question you ability to do this procedure.
You must review the fill procedure and how to vent it also. It's all right there.
Re: Just research it on the timing belt change out procedure
Ok great thanks. I do not appreciate your questioning of my intelligence. I'm not sure ability is judged by the knowledge of what you know how to do but rather the ability to gain knowledge in understanding, but thanks for your info.
Re: You asked questions and he answered 3 times.
I realize this. I was just trying to gain as much information as possible as this is a public forum. Sorry for any inconvenience caused.
