While I'm at it
Old Feb 8, 2005 | 09:22 AM
Excaliber's Avatar
New Member
Default While I'm at it
One more thing. After driving the car and getting out of it, the smell of burnt oil seems very potent. I had the dealer look into it, they replaced the water pump timing belt, and the valve cover gaskets while there. The head has been pressure tested and is good, and I'm not blowing smoke, but damn is it embarrassing driving a fantastic car that smells like a 65 Ford pickup.
Thanks again, the forum has been extremely helpful,
Paul
Old Feb 8, 2005 | 09:39 AM
Jim - 03S8's Avatar
Default Sounds like you need to replace the transmission output flange seal...
I just had it done for $320 at an independent, but you could do it yourself by following the procedure on Audipages.com
Old Feb 8, 2005 | 09:40 AM
Return 4 Deposit's Avatar
New Member
Default Check the transmission output seals...
When they leak (and they do) they drip gear oil onto the hot cat converter. The smell is somewhere between motor oil and body odor.
www.Audipages.com has a buyers guide you should review as well.
Enjoy your 8!
Old Feb 8, 2005 | 09:47 AM
Excaliber's Avatar
New Member
Default Re: Check the transmission output seals...
Appreciate the heads up. I looked through it before I bought the car. Really not fealing that any of this is beyond the cars years, it is a '98 with 71K on it, just a tad frustrating with a miserable dealer involved. Thanks for the help!
Old Feb 8, 2005 | 10:48 AM
PaulW's Avatar
Default Here's the link
<ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission/transealreplacement.html">http://www.audipages.com/Tech_Articles/auto_transmission/transealreplacement.html</a</li></ul>
Old Feb 8, 2005 | 10:57 AM
New Member
Default I see your problem now...
by your signature I see that you have the 4.3 engine. That thing leaks like crazy &amp; there is no way to fix it - ever. Pretty soon you just pour oil in the top and it comes out just as fast through the bottom.
Double check and make sure you don't have the 4.2 engine instead - it's much better :-)
(just having a little fun with you)
Old Feb 8, 2005 | 11:19 AM
Excaliber's Avatar
New Member
Default Re: I see your problem now...
DOH!...My fault, truely....thanks for the jab!
Old Feb 8, 2005 | 11:21 AM
Excaliber's Avatar
New Member
Default Re: Here's the link
Indeed, I looked it over after Return 4 sent it to me. Looking like I will have to have it done, but, that is it on the money, and now that it was mentioned, it does smell of axel grease more so then straight oil. Thanks for the help everyone...onto my second thread!
 Michael S. Palmer
Old Feb 8, 2005 | 11:22 AM
Excaliber's Avatar
New Member
Axle that is....;P
Old Feb 8, 2005 | 11:47 AM
Excaliber's Avatar
New Member
Default Re: Excalibur, you can edit
Always helps...thanks for letting the noobness wear off before lighting the torches!
javanator
Jul 16, 2008 08:36 AM
y'allroad
Audi allroad
Oct 3, 2007 03:01 PM
quattrotto
Jun 1, 2006 01:28 PM
MadMing
Jun 12, 2004 05:49 PM
Me_and_my_GT
Oct 21, 2003 06:39 PM
