04' A8 check engine light
Hello all. I'm hoping someone can help out. Purchased an 04 A8 a couple of months ago. Everything seemed fine. About a week after I got it home I got a check engine light for P1128 and P1130 . I have not driven it much since then, maybe 50 miles and now I have a boatload of codes coming up.
16684 P0300 Random/Multiple Cylinder Misfire Detected
16685 P0301 Cyl.1 Misfire Detected
16686 P0302 Cyl.2 Misfire Detected
16688 P0304 Cyl.4 Misfire Detected
17536 P1128 Long Term Fuel Trim mult.,Bank1 System too Lean
17538 P1130 Long Term Fuel Trim mult.,Bank2 System too Lean
17544 P1136 Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
17546 P1138 Long Term Fuel Trim Add.Fuel,Bank2 System too Lean
17983 P1575 Right Eng. Mount Solenoid Valve Short to B+
17981 P1573 Left Eng. Mount Solenoid Valve Open circuit
18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
Not sure what my first step should be here, have never had that much come up at once before. I do not have a vagcom but I do have an xtool vag401 but am still figuring out how to use the thing. Any help or suggestions would be great.
Okay, calm down. Sounds like a couple of bad motor mounts and I would guess a weak fuel pump. The lean codes and misfires are tied together most likely. For the motor mounts, look to see if there are signs of fluid having leaked out of them. I am not familiar with the P1602 code, though.
+1. For running issues, this would be my starting point. Codes are both Bank 1 and 2, which on a 4.2 means both sides of motor. Lean running can then also generate misfires and those codes. Look carefully at everything from the MAF sensor to the intake manifold proper. Could be as simple as a loose clamp on the joints from the MAF on the way to the throttle body bolted to the intake. The suck pump, vacuum pump--aka 10 other names for the Y fitting that ties in the power brake booster line--hooks up in there somewhere too and can get dislodged. Some like that are often loud enough to hear the air being sucked in. Others just need careful look. From BTDT, my first hunch might be the loose ginormous clamp stuff. Fuel possible too, but vacuum most common at margin and usually pretty easy to either find issue or move on to other common areas as highlighted in the various responses.
Thanks everyone. I'm going to start with the battery, It's showing 11.8 volts so maybe that will take care of some of the codes. Then I'm going to look at the maf and look for vacuum leaks. Am also going to purchase Ross Tech VCDS. Once it stops raining I'll tear into it and report back.Thanks again.
Just an update. Have found several vacuum leaks, a missing hose clamp on the maf section, a bad air filter and a dying battery so far. Have ordered the filter and battery. I do have a question about one vacuum leak. One was simple, just a cracked hose. The other was just missing. There was a vacuum fitting on the air box (pic one) and the only other missing fitting I could find was the one in pic two. I searched around and am thinking it must be something with the secondary air system. I just wanted to check before I put it all back together.
AudiWorld Wiseguy
The air box fitting is for a vacuum operated flap that opens up under large throttle openings. There should be a hose nearby just hanging loose that fits into it. There should also be a sticker under the hood with a schematic diagram of the vacuum system to help you identify what is what.
That was the thing, could not find any loose hose. Pic two was the closest non-connected fitting I could locate. I'm 90% sure that's where it goes, just wanted to verify from someone more knowledgeable than myself.
