Sponsored by:
Sponsored by:
07 A8 4.2 VCDS Scan Results. Please tell me what you see
Old 07-21-2018, 03:08 PM
  #11
Dalplex's Avatar
May I suggest removing all no fault code section?
For PB 53. Can you verify both 12 v power via 30a fuse in the trunk and terminal 15 ( switchable signal) from passenger fuse box available to the unit?
Old 08-17-2018, 11:02 AM
  #12
pelletman's Avatar
OK, I have 12V on the two rear fuses. Stupidly I pulled apart and checked the relay on the drivers side that I had recently replaced, and there is 12v on the three terminals on the right and no voltage on the one on the left, with the key off. I checked terminal 15 in the passenger's side fuse box and there is 12 volts with the ignition off. Any help is appreciated!
I'll rescan and remove the no fault sections before I repost
Old 08-17-2018, 11:59 AM
  #13
pelletman's Avatar
When I go into 53 - parking brake I get no response. I used to get a response
I get this from ABS
Friday,17,August,2018,15:55:47:24716
VCDS Version: Release 18.2.1 (x64) Running on Windows 7 x64
Ross-Tech: Home
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Control Module Part Number: 4E0 910 517 B HW: 4E0 614 517 BC
Component and/or Version: ESP 5.7 allrad H44 0510
Software Coding: 0008597
Work Shop Code: WSC 02313 000 00000
VCID: 221D1613B8C9F9D7473-8076
3 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
004 - No Signal/Communication
00003 - Control Module
014 - Defective
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Old 08-17-2018, 12:22 PM
  #14
pelletman's Avatar
OK, here are the codes
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Not registered 0001
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0011
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels:. 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: --H16--- Serial number: AUX3Z0F4793999
Coding: 01060009190F0120
Shop #: WSC 01013 444 54617
VCID: 20191C1BB6C5EBC7517-8074
4 Faults Found:
000545 - Angle Sensor 2 for Throttle (G188)
P0221 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 252484 km
Time Indication: 0
Date: 2018.07.19
Time: 11:35:47
Freeze Frame:
RPM: 1305 /min
Load: 32.5 %
Speed: 52.0 km/h
Temperature: 72.0°C
Temperature: 26.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 252484 km
Time Indication: 0
Date: 2018.07.19
Time: 11:35:47
Freeze Frame:
RPM: 1235 /min
Load: 36.1 %
Speed: 52.0 km/h
Temperature: 72.0°C
Temperature: 26.0°C
Voltage: 14.097 V
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 252484 km
Time Indication: 0
Date: 2018.07.19
Time: 11:36:28
Freeze Frame:
RPM: 693 /min
Load: 32.9 %
Speed: 4.0 km/h
Temperature: 78.0°C
Temperature: 27.0°C
Voltage: 14.351 V
005137 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 253747 km
Time Indication: 0
Date: 2018.08.15
Time: 09:59:42
Freeze Frame:
RPM: 1049 /min
Load: 49.4 %
Speed: 9.0 km/h
Temperature: 34.0°C
Temperature: 30.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.081 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0010
Revision: --H01--- Serial number: 4184960
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 23131317A7D3F0DF4C5-8076
1 Fault Found:
049448 - No Communications with Parking Brake Control Module
U0128 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 252484 km
Time Indication: 0
Date: 2018.07.19
Time: 11:35:48
Freeze Frame:
RPM: 1248 /min
RPM: 1184 /min
RPM: 1376 /min
(no units): 37.0
(no units): 42.0
Temperature: 40.0°C
T.B. Angle: 9.4°
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
2 Faults Found:
014 - Defective
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F4793999
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58E974FBAE156307697-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 201
Mileage: 253008 km
Time Indication: 0
Date: 2018.07.27
Time: 14:23:20
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 0
Reset counter: 209
Time Indication: 0
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 209
Mileage: 253936 km
Time Indication: 0
Date: 2018.08.17
Time: 15:34:02
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 00000 785 00200
VCID: 2411100BA2DDF7E735F-8070
5 Faults Found:
01730 - Switch for Seat Height Front Pass. Seat (E65); Up
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 2
Reset counter: 209
Mileage: 253936 km
Time Indication: 0
Date: 2018.08.17
Time: 14:51:03
01731 - Switch for Seat Height Front Pass. Seat (E65); Down
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 209
Mileage: 253936 km
Time Indication: 0
Date: 2018.08.17
Time: 14:51:03
01733 - Switch for Head-Rest Adj. Pass. Seat (E170); Down
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 209
Mileage: 253936 km
Time Indication: 0
Date: 2018.08.17
Time: 14:51:03
01732 - Switch for Head-Rest Adj. Pass. Seat (E170); Up
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 209
Mileage: 253936 km
Time Indication: 0
Date: 2018.08.17
Time: 14:51:03
01729 - Switch for Seat Height Rear Pass. Seat (E66); Down
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 209
Mileage: 253936 km
Time Indication: 0
Date: 2018.08.17
Time: 14:51:03
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000097286
Coding: 0037185
VCID: 1C6128EB9AADCF278DF-8048
3 Faults Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 19
Reset counter: 151
Mileage: 252123 km
Time Indication: 0
Date: 2018.06.23
Time: 04:23:33
Freeze Frame:
Temperature: 34.0°C
00710 - Defroster Flap Positioning Motor (V107)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 253730 km
Time Indication: 0
Date: 2018.08.14
Time: 20:23:31
Freeze Frame:
Voltage: 13.00 V
Temperature: 24.0°C
(no units): 84.0
(no units): 79.0
Temperature: 44.0°C
Raw, Form. N/A: 000 000 000
00819 - High Pressure Sensor (G65)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Mileage: 253938 km
Time Indication: 0
Date: 2018.08.17
Time: 14:55:44
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0005ZMC
Coding: 0532707
VCID: 26150A03D4E105F72BB-8072
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 36LY6
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ† 63
Subsystem 4 - Serial number: 000000ÿ† 63328RB40130ED29Kÿ† 63
Subsystem 5 - Serial number: 0ED29Kÿ† 63428RB40130ECFAYÿ† 63
Subsystem 6 - Serial number: 0ECFAYÿ† 63528RB40130ED00Bÿ† 63
Subsystem 7 - Serial number: 0ED00Bÿ† 63628RB40130ECFB.ÿ† 63
Subsystem 8 - Serial number: 0ECFB.ÿ† 63729RB401322E74Gÿ† 63
Subsystem 9 - Serial number: 22E74Gÿ† 63829RB401322E43Dÿ
Subsystem 10 - Serial number: 22E43Dÿ
1 Fault Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 209
Mileage: 253938 km
Time Indication: 0
Date: 2018.08.17
Time: 14:55:42
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B064258167
Coding: F5D1DF7F30720E
Shop #: WSC 11111 111 45725
VCID: 6C81382B0A8DFFA7BDF-8038
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 169
Mileage: 252391 km
Time Indication: 0
Date: 2018.07.17
Time: 16:37:15
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 134
Mileage: 252391 km
Time Indication: 0
Date: 2018.07.17
Time: 16:37:20
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 209
Mileage: 253938 km
Time Indication: 0
Date: 2018.08.17
Time: 15:34:03
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0019911
Shop #: WSC 11111 111 45799
VCID: 2809043BDEF51387197-807C
3 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 109
Reset counter: 209
Mileage: 252391 km
Time Indication: 0
Date: 2018.07.17
Time: 18:21:01
01400 - Suspension Level Control
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 182
Mileage: 252495 km
Time Indication: 0
Date: 2018.07.19
Time: 13:20:16
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 191
Mileage: 252564 km
Time Indication: 0
Date: 2018.07.19
Time: 18:05:15
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H04 0090
Serial number: 00000612400012
Coding: 0003477
VCID: 1D6725EF81B7C62F7A1-8048
1 Fault Found:
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 198
Mileage: 253392 km
Time Indication: 0
Date: 2018.08.11
Time: 18:55:00
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040605190397
Coding: 0048702
Shop #: WSC 12345 111 45725
VCID: 2A0DFE33C0F921970F3-807E
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
2 Faults Found:
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 196
Mileage: 253338 km
Time Indication: 0
Date: 2018.08.11
Time: 12:01:54
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 207
Mileage: 253626 km
Time Indication: 0
Date: 2018.08.14
Time: 13:39:13
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000086006
Coding: 0010111
VCID: 1E6522E38CB1DD3763B-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T151305
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 209
Mileage: 0 km
Time Indication: 0
Address 53: Parking Brake
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000009046
Shop #: WSC 00000 128 00289
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2605170302
Coding: 344530393135313035412056413032363035313730333032
1 Fault Found:
02256 - Quiescent Current
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 15
Reset counter: 208
Mileage: 252481 km
Time Indication: 0
Date: 2018.07.19
Time: 04:18:18
Old 08-17-2018, 12:23 PM
  #15
pelletman's Avatar
I had communication with the parking brake earlier. The only thing I can think of that I did that may affect that was change the relay on the drivers side and I did pull out the parking brake module to check the numbers on it but I think it scanned after that. Any help is appreciated!
Old 08-17-2018, 12:26 PM
  #16
pelletman's Avatar
Originally Posted by jlbell
This might help:
Replace the relay before you replace anything else. They are cheap: https://www.europaparts.com/relay-1k0951253a.html
This is the relay I changed. I think the old one said 460 and the new one said 370
Oh, and the parking brake DOES work, at least until 1000 RPM. I am guessing the rear pads may have been changed by someone who didn't know what they were doing. I think they could use recalibration, but I can't communicate with the controller so...
Old 08-18-2018, 04:54 AM
  #17
Dalplex's Avatar
Parking brake DOES work. Does this means lock and release pads by press/ release button? Then it would be strange.
Old 08-18-2018, 05:28 AM
  #18
pelletman's Avatar
Yes ,that is what I am saying
Old 08-18-2018, 07:34 PM
  #19
Smoov4545's Avatar
Default ABS,ESP, PARKING BRAKES MALFUNTION
Can anyone help ...... on another note the first time I scan my car with VCDS the code I was getting was ( ABS SENSOR FRONT LEFT , BRAKE LIGHT SWITCH AND ABS CONTROL MODULE .
Old 08-20-2018, 03:29 PM
  #20
pelletman's Avatar
Probably shouldn't hijack my thread
Quick Reply: 07 A8 4.2 VCDS Scan Results. Please tell me what you see
