A8 not recognizing key fob when approaching
I went to the stealer numerous multi-hour days over this and a few other items with no remedy. Finally they ordered an antenna replacement, I think there are four total.
Anyhow, the tech realized my car battery was weak and croaking out on him while in the service bay. Apparently when the battery goes dead or close to it, the car has a safety measure which includes shutting certain things down so something 'bad' doesn't happen. When this happens, I was told the tech needs to 'reset' or 'reprogram' the auto lock/unlock feature.
In the end, they 'reprogrammed' my rig and didn't even need the antenna they had. The auto lock/unlock now works, albeit with some inconsistencies due to my weak battery.
I scratched my head and asked about replacing my battery and if in doing so i would be without auto lock/unlock again due to the battery being disconnected. The service manager put his hands up and said maybe.
VCDS should tell you about quiescence due to low voltage and/or the module being an issue.
Also periodically use the key in the ignition.
Apparently, or so I was told, it syncs the system - every time mine got flaky this resolved it.
Also can be any of the other things mentioned in replies or OP. Can also be the key (batteries aside) if it gets dropped, washed or otherwise abused enough. Like cell phone connectivity, I think sometimes folks jump to the car side a lot, even if the small device is the thing most obviously abused by everyday use. Here the OP says it affects both keys though, so less likely. Takes me back to maybe the main car battery if keyless either works or not, like a light switch. I would expect antenna issues, weak fob batteries etc. to be more variable by range.
Last item: watch out for cell phone RFI interference. My key absolutely hates being in the same pocket as my iPhone. They have to go in opposite pockets or I have to take one or the other out when they get into same pocket as the day goes on. Otherwise, door frequently just stays locked until I separate the electronic kids.
Probably FOB battery. New one doesn't always mean good one. VCDS will show if this is the case.
