A8L 3.0 no start issue
#22
I finally made it to check the fuses and i had to change some i now get power to obd2. The codes i get are:
00184 activation for engine Start/stop switch
00166 access/start autorization switch
00185 relay for voltage supply terminal 15 adaptation
02072 energy management control module -j644
You need the codes i get in the immobiliser menu as well?
I am starting to wonder weather this car will ever run again?
#23
Hello again ,
I order kessy module , ecu ,key and key ignition , complete string
wheel column , cluster
are you think this work ?
#24
How did you make out with your A8L, yes we would need all codes, do you, or can you get a copy of the scan you say was done, and was it done while this problem existed?
Also, with just your generic codes, they give no explanation as to the cause of the fault code as a Ross-Tech scan would, such as open or short to ground, ETC.
Such as these found online
4 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 33
Mileage: 214225 km
Time Indication: 0
Date: 2003.10.18
Time: 11:58:49
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Priority: 3
Reset counter: 33
Mileage: 214225 km
Time Indication: 0
Date: 2003.10.18
Time: 11:58:49
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Reset counter: 34
Mileage: 193858 km
Time Indication: 0
Date: 2011.08.15
Time: 01:50:33
#27
#30
Thanks
What happened to Rik ??
Kam,
See link, info starting at post # 47
https://www.audiworld.com/forums/a8-...2905353/page5/
Kam,
