Any way to disable adaptive light warning?
I know it's been mentioned before that perhaps pulling their fuse, but does anyone have experience getting rid of the adaptive headlight warning besides replacing/repairing the headlight?
I did try pulling the fuses indicated in the panel, but the warning and alert still pops up whenever the car is started.
Audiv10 (11-23-2021)
No, There is No Way to Disable
1. The control module. Can DIY with some difficulty. Cost 1K at dealer, about $345 OEM NEW. They are known to fail due to water intrusion.
Power module for cornering light for 2008 Audi S8. #4F0941329D
2. The Sealed headlight. The curve motor and sensor are in the sealed beam and can not be replaced individually. Very costly at dealer, like $2K, used 500-600 and will require removal of front bumper cover. Not cheap or easy.
3. The connector. There is a 14 pin connector at the lower back of the headlight (B!tch to get at!). Interestingly, it's a male connector with female tines inside that loosen up over time (known issue). Disconnect and use a pick to gently pry them back together. This worked for me and $0! Alternately, the entire connector costs $15, but will need special tools-skill to replace or soldering skills. I found the info about this on ROSS, about the Passat which uses much of the same tech as AUDI, and certainly the same connector:
02628 - Ross-Tech Wiki
Chinese connector with pigtail:
http://www.ebay.com/itm/251897886628?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
OEM Connector:
HOUSING | Genuine Volkswagen | 1J0-973-737
Unfortunately, there is no way to disable the warning. I fought this for a long time on my passenger side. There are three things that can go wrong:
New Headlamp Front Lamps Connector 14PIN for VW Golf MK6 1J0973737 | eBay
OEM Connector:
OEM Connector:
Excellent
OEM Connector:
OEM Connector:
Symptoms?
Great post. Can you or anyone else on this thread tell me what symptoms they experienced to help diagnose the problem? I have the warning message flashing constantly, but don't know where to start. The lights are all on as normal when stationary and I haven't driven at night for a while to notice anything unusual with the adaptive pointing.
OEM Connector:
OEM Connector:
Pul the Codes
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Shop #: WSC 41776 001 1048576
VCID: 295904A98012A656EC9-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH02 0010
1 Fault Found:
02628 - Sensor for Swivel Module Position; Right
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 110168 km
Time Indication: 0
Date: 2015.02.17
Time: 18:20:07
I also started getting the defective message on my 2007 A8. Mine appears to be the driver's headlight cornering motor. Up/down tests work, but motor won't swivel side to side when I run test in VCDS. I'm not looking forward to dealing with that bumper or possibly ordering a new $1100 light but in my case, as I understand it from some of the other threads, the motor itself isn't replaceable, although some of the parts diagrams online appear to show the motor part# in the part diagrams.
Hopefully your fix is a less expensive solution.
Here is my scan:
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Coding: 0000018
Shop #: WSC 02313 785 00200
VCID: 2959D8A180EC94762A-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
02627 - Dynamic Cornering Light Motor; Left (V318)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 35
Reset counter: 199
Mileage: 157624 km
Time Indication: 0
Date: 2015.10.05
Time: 19:44:40
Here is my scan:
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 35
Reset counter: 199
Mileage: 157624 km
Time Indication: 0
Date: 2015.10.05
Time: 19:44:40
I've posted regarding this before, but on a MY 2004 that does not corner, only adjusts with the suspension height. When I had the error it only occurred when it was damp or had rained. It turned out I did not properly close the access cover after replacing the Xenon lamp. Once it dried our in a few days, all was well until it rained again.
I used a hair dryer to dry the interior our and then properly closed the cover and all has been well since. Net cost was my time.
