Sponsored by:
Sponsored by:
Aux/parking heater
Old 10-24-2012, 04:08 AM
  #11
volvopentaman's Avatar
Originally Posted by snapdragon
It was not generally fitted to EU models.
The Webasto was only fitted as standard to diesel powered models as they struggle to get up to temperature without it due to their efficiency. This was called an auxiliary heater.
Wrong there, all D3:s i've seen have had the aux heater installed, and i've seen dozens of them. The european w12 and s8 v10 have it as standard in most countries, even germany.
And about not fitting the NA w12, it fits as well as to the european, even the european has an heat exchanger below the right headlamp, and the aux.heater still fits there.
Tough, you are unable to fit an electric water heater to the W12, atleast without a circulation pump, because the w12 has both radiator hose connectors on top of the engine block, so the electric heater would only heat the hoses without a circulation pump (i was about to do that to mine).
Mercedeses are good objects to fit electric heaters (have fitted around 400 electric heaters to sprinter and vito vans, to a,b,c,e,g,gl,ml and s-series cars). Most of these, except the a and b series and gas engines and V-engines have a plug in the engine block to screw in a electric heater, the a+b series gas engines get a oilpan heater and the V-engines get a hose heater at the lower radiator hose.
Had an electric heater in my Volvo 360 (volvo B200F engine) and that heated the engine to 60-70degrees celcius even at -20degrees in less than an hour. I hope i could install one of these even to my audi, but I don't like the idea of drilling and threading a hole in the lower end of my W12 engine block's waterchannels.
My idea would be to install an oil-pan heater, that is glued onto the bottom of the oilpan, not as efficient as the water heater, but will do the trick, tough the webasto aux-heater is much faster.
Old 03-28-2013, 10:59 PM
  #12
wug
wug's Avatar
I have parking heater on my A8 but when i got the car the remote control T70 was missing. Meanwhile i got a T90 remote control and i have no idea how to code it in via VAGCOM. Any advise?
Old 03-29-2013, 01:38 AM
  #13
Adaptation, channel 04
http://www.audi-portal.com/en/diagno...u_11246.html#1
Old 03-29-2013, 01:52 AM
  #14
wug
wug's Avatar
Thanks for quick reply. Looking at ETKA i see the T70 remote works on >>4E-4-030 000 and T90 works on 4E-5-000 001>>. My VIN is WAUZZZ4E64N019598. My heater unit is 4E0 265 105 L and Heat Exchanger Housing for Coolant Circuit is 4E0 819 953 C.
I have tried the VCDS procedure but nothing happend. Also tried with removing the battery for 5 mins and no success as well.
Old 07-17-2013, 03:24 AM
  #15
wug
wug's Avatar
If anyone interested i have a webasto remote Audi T90 4F0909507B. Great condition but will not fit my car. Fits newer model after 2007 year like A6 and A8.
I got the T70 and works flawless with mine.
Kerry G
05-18-2018 06:12 AM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
jeffkruse
10-02-2015 09:19 PM
gakor
09-27-2015 02:10 PM
ECS Tuning-Audi
09-03-2015 12:45 PM
Quick Reply: Aux/parking heater
