Clunking in comfort mode but not in dynamic mode?
So im test driving this 07 a8 and I feel clunking on patholes and bumps while in comfort mode but not in dynamic mode. What does it mean? Strut inside of the air shock is bad so it needs new air shock? Suapension seems to go up and down no problem. Milage 90k. Or maybe a control arm? Bolt joint? Thanks
I figure after so many issues with these things, someone may have idea without troubleshooting or from past experience. Yes, I know - I can take it to the mechanic but I haven't bought the car yet.
It will be one or more of the many bushes on the front suspension, in Dynamic the car sits lower, so the bushes are stressed differently which removes some of the symptoms (for a little while at least).
Poor engineering and the reason I'll never own another Audi.
Yeah, blame the engineers. I'd put money on the fact that they are probably looking in the wrong place. Heck, a clunk in my brother's D3 had all sorts of expensive diagnosis' but turned out to be a loose belly pan. I had a noise I swore was in the front, but turned out to be a rear brake pad clip rubbing on the rotor. The point is that your issue is with the diagnosis, not the design.
Something simple like wheel balance can be a real fooler. WHen I first got my car I had a vibration at speed. I would have sworn that one or more of the front wheels were out of balance. It was a rear wheel that was out. The frame is so rigid that vibrations travel the entire length of the car and that really can mess with your perception of the where the problem is.
1. Is non returnable if it doesn't fix my issue according to Audi dealers
2. Probably won't fix my issue since before putting on the "crappy rebuilds", we put on two different sets of brand new Arnotts and same issue.
