COOLING SYSTEM CAP PROBLEM???
ONLY WILL LEAK OVER NIGHT SOMETIMES BUT NOT DRIVING OR PARKING AT WORK.
COOLANT RESERVOIR WAS REPLACED BY DEALER 1 YEAR AGO. SYSTEM ALWAYS HAS PRESSURE WHEN YOU REMOVE CAP, EVEN AFTER SITTING ALL NIGHT. I THINK MY CAP MAY BE DEFECTIVE SO OVER NIGHT COOLANT SEEPS OUT OF PUMP! ANYONE HAVE SIMILAR ISSUE???
Cheers,
Louis
If it's that seal area drain hole, only fix is a new water pump, which then invites the timing belt job question. And similarly, if the seal, you neither want to run the risk of running motor w/out coolant nor that the seal leak issue getting into the pump bearing and eventually freezing up. That is more a very extended neglect scenario and usually accompanied by squeals or gravelly bearing failure kinds of noises, but it makes sense to resolve pronto anyway.
BTW, on the cap it shouldn't ever release pressure under normal operating scenarios, so a cap malfunction here wouldn't be the cause. Instead, per the normal operation, the system stays under pressure for some hours as the motor cools down. Unless the car overheats and the cap then dumps the coolant to the ground under a lot of pressure, if anything the cap functions more in the other direction. Thus, if the car is low on coolant and has more resulting air volume in the cooling system, when a vacuum condition develops (like the system cooling down), the cap can let air back in to the reservoir area so the hoses don't start collapsing.
Thanks!
That belt and pump done 30K ago is interesting but again not determinative. Failure rate is > 0 regardless of miles; it just goes up more later. Net, if you have timing belt and engine covers off, you want to get to exactly where the leak/drips come from, like literally within a few millimeters. Without that, you are on a wild goose chase and then we're all just guessing.
4.2 set up will be different on specifics, but in general I would trace your overflow line back looking for leaks. If you find a very faint pink crusty sort of deposit on or near any line, clamp or hose, that's where a leak resides. That pinkish stuff is the coolant residual as it burns off; helpful for finding leak sources actually.
OK - The symptom of the coolant pipe is this - over 120k miles both of my D2 32V and 40V.
The leak is on the passenger side - by the starter -
Only leaks when the pressure of the system is high = Hot and engine OFF, will not leak when engine is running.
Leaks a little - then a lot after a few weeks.
Cheers,
Louis
