D3 "Easter Eggs" - Obscure Features
#41
2015 A8L TDI
remember the Lexus that crashed with 4 people in it because the throttle stuck? Lexus said all they had to do was hold the STOP button for 3 seconds to kill the engine anytime.
Well, my Audi does NOT have that feature...guess I know how i'm gonna die
#42
Another good reason for throttle by wire.
#43
Also, holding the parking brake will activate all four corners at maximum pressure. Just make sure you batten down the hatches before you try that one, it stops you quick enough to detach your retinas.
#45
Great bunch of jewels. I knew about some of them including the "little sunshade". Unfortunately, it's a waste. The sun is inevitably between the mirror and the driver's shade. I've seen some American iron where the left and right shade extend towards the mirror, going behind to block out that pesky sun. I am also going to check out if the rear sunshade goes down in reverse. I like mine up all the time because I keep a big umbrella on the rear shelf and UV from the sun rots it.
I've never seen the gas cap light. Maybe I'll experiment with it. I find the windshield squirt adjustment impossible. It could be my big head, but i can't see what I'm doing and may not be using a big enough needle. I do remember back in HS biology class we had a wooden stick with a needle in the end. Bio teacher instructed us to "pith" the live frog by sticking in the brain stem. This paralyzed it to allow dissecting so you could see the heart beat. (yeah, back then PETA would have had a field day with my teacher)
The biggest myster for me it not specifically about the gas tank min-reservoir. But the strange gas tank over all. I'd love to see an explanation of the gas tank "chambers", why two pumps and how all of it works.
Thanks
Thanks
#46
AudiWorld Wiseguy
http://www.volkspage.net/technik/ssp/ssp/SSP_282_d1.pdf
#47
2015 A8L TDI
#49
That was sweet, but so is this one.
#50
Try both sides; when I got my first 2004 the driver's side was quite stiff to put up or down and apparently did not extend. The passenger side did, though. Found them on Ebay for ~25 bucks and decided to try fixing mine knowing the worst case scenario would be buying one there. Took it off, no apparent way to disassemble, so I lubed the shaft with something aerosol & plastic safe and it loosened it up enough to pull it out (with great effort). Put some silicone grease on it (which was clear to start and quickly became dark grey), worked it in & out, and that has helped, but I'm constantly thinking I should buy one because it's still really difficult to move. If I ever do, I'll dissect the old one and get to the root of the problem and post it.
