Does AUDI cover tires under warranty?
If you have the TPMS system and you are noticing a slow pressure drop ...
don't assume you have a tire problem. If you can't see an offending object in the tire, check the tightness of the metal valve stem. Use a socket head and, using your fingers only, tighten the stem slightly. It clamps through to the sensor and there is a small rubber O ring on the well side. Sometimes this is a little loose and can leak giving the impression of a slow puncture.
Never said it couldn't be, just tightening the valve stem is cheaper!
Happened on my 05 on both one of the OEM wheels and one of the 20 inch replacements. Nipping the valve stem sorted the problem.
GrandPaJohn
Wheels & Tires Discussion
01-21-2009 06:38 AM
cellogig
04-19-2006 11:13 AM
Crazy Quattro
02-21-2005 06:03 PM
lauk0dg
05-20-2002 01:02 PM
mpatient
01-08-2001 04:38 AM
