Does the glove box light have a fuse
Old Apr 22, 2011 | 02:55 PM
brisweeney's Avatar
Default Does the glove box light have a fuse
I had a spare led bulb after changing out my courtesy lights under the doors so decided to see what bulb the glove box takes. It's the same as the door so tried an led, didn't work, in either polarity, strange thing is now the old bulb won't work either.
So I'm wondering is there a fuse some where for the light in the glove box, is so, where, and would it likely be blown by me doing this?
Thanks guys
Old Apr 22, 2011 | 04:15 PM
Jake-AudiUSAParts's Avatar
Banned
I do not believe the glove box light has a fuse. However the hydraulic brake that controls the open and close speed of the door also turns the light on and off. That brake/switch could be the culprit. I have them in stock 8E1-880-324-A $21.98.
Old Apr 22, 2011 | 04:44 PM
mishar's Avatar
Tech Guru
All circuits are fused. Glove box light is most likely with some other small device at the same fuse. If everything else is working than it is not a fuse. Try some other bulb. You just changed few of them for LED's. Could be the switch too, but that would be odd coincidence if it was working before you decided to try LED.
Old Apr 22, 2011 | 07:29 PM
williebone's Avatar
Check VCDS to if you threw a Fault Code and Clear it. Laters,
Old Apr 24, 2011 | 01:00 AM
Hilden's Avatar
I have the same problem but my old bulb didn't work either. Might try replacing the switch Jake mentions
Blackchim
A7
Feb 26, 2015 06:48 AM
ghodder
Jun 13, 2008 04:15 PM
eppik
Apr 12, 2003 07:37 AM
HenryK
Audi 100 / A6 (C4 Platform)
Jan 30, 2003 09:14 AM
CanyonBlaster
Nov 4, 2002 04:40 AM
