Engine Decarbonization?!
Old May 19, 2012 | 04:27 PM
abarmard's Avatar
Default Engine Decarbonization?!
I was told that decarbonizing an engine will improve gas mileage as well as engine performance. Is that ture? How is that done? How much does it cost to do it? it it worth doing it for a 2004 A8L?
Thank you,
A.
Old May 19, 2012 | 09:18 PM
mishar's Avatar
Tech Guru
That's right, if there are serious deposits. In order to clean them cylinder heads has to come down and be completely disassembled. Best think to do is to use some injector cleaner, Techron for example. It will clean injectors and improve performance and millage. Just don't expect miracles.
Old May 20, 2012 | 05:05 AM
PaulW's Avatar
Default You have an 04 - Most likely never necessary
You do not have direct fuel injection, you have the style that sprays the fuel in the intake, it mixes with intake air and this mixture passes by the valve stem, cleaning everything. It's the car's with FSI (direct injection) that have issues with carbon build up. Nothing for you to worry about. If you put Techron in, it helps keep the injectors clean and prevents fault codes in the future due to misfires.
Old May 20, 2012 | 07:49 AM
mishar's Avatar
Tech Guru
FSI engines are more likely to have deposits, but all engines can and will have them if oil is coming into intake. Worst ones are inside the combustion chamber. They work as a glow plugs causing self ignition/detonation/pinging and eventually burning pistons and cylinder head. I doubt that ever happened to an A8 engine.
Old May 20, 2012 | 12:25 PM
abarmard's Avatar
Default Thank you
Thank you guys for the input.
I did buy a few bottles of Fuel injector from Costco, How often should I use them?
Thank you again,
A.
Old May 20, 2012 | 01:10 PM
mishar's Avatar
Tech Guru
They recommend it every third refueling.
Old May 20, 2012 | 02:36 PM
PaulW's Avatar
That seems much too frequent. Of course they want you to do it every third fill up. I would say 2 bottles once a years is all you need.
OldCowboy
A4 (B8 Platform) Discussion
May 31, 2025 07:41 AM
alex69
Oct 7, 2005 06:08 AM
HarnessedLunacy
Mar 25, 2004 08:43 AM
Rennen
Mar 10, 2002 01:02 PM
Hawaiiannights
Jan 12, 2001 05:56 AM
