the engine does not start
Old Mar 17, 2017 | 06:08 PM
Raspi's Avatar
Default the engine does not start
Audi A8 D3/4E
The engine starts only on a cold one. Warms up and stalls. Stalled and does not start again. Remove the battery terminal, then after 20 minutes, start the mojo. Runs 2 minutes and again the stalls. You can turn off the left row of injectors and start again. what is the problem?
Old Mar 17, 2017 | 06:18 PM
Jack88's Avatar
Well, there could be a couple things. Usually, that seems to be a crankshaft position sensor. It's a fairly well documented failure, and doesn't always produce a trouble code.
Old Mar 17, 2017 | 10:20 PM
mishar's Avatar
Tech Guru
It is underneath the gearbox in the flywheel area.
Old Mar 18, 2017 | 12:09 AM
Raspi's Avatar
Thank you very much. I will change the sensor and write the result.
Old Mar 18, 2017 | 05:43 AM
Mister Bally's Avatar
Before changing that sensor, I would run a diagnostic scan with the Ross-Tech interface or proper dealer tool. A fault code should be stored (no MIL light lit though). Otherwise you could be starting a long road of wasting money throwing parts at the car.
You could also have a fuel pump problem.
Read and heed the sticky at the top of this D3 A8 thread.
Old Mar 19, 2017 | 11:00 PM
Raspi's Avatar
Hello. Forgot to tell you. Trouble after engine exchange. My car for the American market WAUML44E94N000848. And the engine bought with the car for the Japanese market (right-hand drive) WAUZZZ4E66N004277 wires all set mine, the control unit too.
Old Mar 20, 2017 | 04:21 AM
Raspi's Avatar
Hello, we have only Hanatech Ultrascan P1 and Launch X431 IV
Old Mar 24, 2017 | 09:25 AM
Raspi's Avatar
Thank you all. Solved the problem. The crankshaft position sensor had a small metal shavings. I cleaned the sensor and it worked.
 Pouria Savadkouei
 Michael S. Palmer
KEVOZS8
28
Aug 13, 2017 04:34 AM
SoCalJ
12
May 20, 2014 11:29 PM
ourv12
15
Jul 28, 2010 03:53 PM
Merkin
10
Mar 1, 2005 06:02 AM
kelleybr
9
Dec 15, 2003 02:35 PM
