EPC Light On After Intake/Injector Cleaning
2007 D3 4.2 - oil was leaking from oil filter housing so I planned to also clean the intake manifold and intake valves and replace the valley pan gasket. I also cleaned out the throttle body and flushed the PCV valve. I chose to use the walnut blasting method with the adapter and vaccuum. Took my time - double checking all connections and making sure everything was back in order. Removed all plugs to clean and check for any debris. Went to start car after reassembly and car cranked once and would not turn over - EPC and check engine light were on. I'm new to VAG-COM, but understand the basics. I wasn't showing any misfires or engine-related codes which I thought was strange. My thought was fuel related since I had to disconnect fuel lines. I've triple checked everything and all seems in order connection wise. The car seems to be locked down now which makes me think some adaptation is needed. After playing with VAG-COM some more and research online - I really couldn't find a good list of adaptation steps to take. I was able to successfully run a fuel pump adaptation (according to VAG-COM), but I'm thinking there's more to it than that. Any ideas and/or proper VAG-COM steps to take here?
AudiWorld Wiseguy
EPC light comes on if the engine doesn’t start (amongst other things. Much like the old school battery lamp, to indicate no charging current flow.
Anyway, given that you’ve had the intake off and consequently disturbed the fuel system, I’d suggest it’s just air in the fuel line. Crank it over some more and it should come back to life.
I've Not Seen
How-To: C6 S6 Intake Manifold Removal & Carbon Clean
The Audi S6 S8 5.2 V10 carbon clean thread.
any reference to adaptions after doing a carbon clean on any write up of the procs.
I would potentially try cracking a fuel line at the high pressure fuel pump to see if it is pressurized, it should be. If not, there is no fuel to the rail. You could probably jump the fuel pump relay (or maybe VAG-COM will run it for you under output tests, don't know) with the line cracked to see if you get fuel flow.
When you say it cranks for a half a second and shuts down, are you saying it does not catch and then it shuts down before catching?
If you haven't tried cracking the fuel rail to see if it is pressurized, I would do that. Running the pump is not enough. It could be like the Audi R8 at Watkins Glen last weekend, they ran the car very low on fuel, then it stalled on pit lane and they couldn't get it primed again after the refuel.
I could be wrong also....but it's a good test. I don't know if you can read fuel pressure in VAG-COM, but if you can, that's another good thing to look at. I think it does look at the high pressure side, but am uncertain.
