Fault Codes?
If anyone could give me any input, before I reset them it would be helpful. the car is going to the dealer next week, (under an extended warranty) and any input would be helpful.
I just seem to be saying thanks to everyone on the forum right now, but the car is very different to my old S8.
So thanks again.
Wednesday,06,February,2013,18:36:35:00217
VCDS Version: Beta 12.10.2 (x64)
Data version: 20121222
Chassis Type: 4L0
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 18 19 1E 28 34
36 37 38 3C 42 46 47 4F 52 53 55 56 57 61 62 67 6C 72 76 77
VIN: WAUZZZ4E19N003560 Mileage: 82800km/51449miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 1010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 409 D HW: 4E1 907 409 A
Component: 4.2L V8TDI G000AGMª0020
Revision: --H05--- Serial number: AUX3Z0H5352953
Coding: 0011773
Shop #: WSC 66565 257 00032
VCID: 25413DD8ECE1DF36DBB
3 Faults Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 6
Mileage: 81928 km
Time Indication: 0
Date: 2013.01.07
Time: 00:02:30
Freeze Frame:
RPM: 756 /min
Torque: 163.8 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.17 V
Bin. Bits: 00101000
Torque: 386.1 Nm
006464 - Powertrain Databus
P1940 - 001 - Missing Message from Control Module for Battery Monitoring - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Mileage: 82616 km
Time Indication: 0
Date: 2013.02.04
Time: 19:35:17
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
(no units): 25.5
Bin. Bits: 00000000
005697 - Please check DTC Memory of A/C Controller
P1641 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 82805 km
Time Indication: 0
Date: 2013.02.06
Time: 17:46:47
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Bin. Bits: 00101000
Bin. Bits: 00010000
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 S HW: 09E 927 156 B
Component: AG6 09E 4,2 TDI RdW 0010
Revision: --H01--- Serial number: 0125669
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 3365D3805235B18645F
1 Fault Found:
006231 - Load Signal
P1857 - 001 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 82805 km
Time Indication: 0
Date: 2013.02.06
Time: 17:48:21
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 30.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 CP
Component: ESP 5.7 allrad H50 0540
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 2A5BCEE485FFF04EF69
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H5352953
Coding: 0412672
VCID: D8BFC42C6B1332DE10D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
5 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 238
Mileage: 80928 km
Time Indication: 0
Date: 2012.12.30
Time: 19:39:26
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 218
Mileage: 81920 km
Time Indication: 0
Date: 2013.01.07
Time: 14:56:12
01176 - Key
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 240
Mileage: 82592 km
Time Indication: 0
Date: 2013.02.04
Time: 17:21:36
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 244
Mileage: 82592 km
Time Indication: 0
Date: 2013.02.04
Time: 17:44:44
00166 - Access/Start Authorization Switch (E415)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 14
Reset counter: 244
Time Indication: 0
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
VCID: 244720DCE7DB263ECC5
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 244
Mileage: 82604 km
Time Indication: 0
Date: 2013.02.04
Time: 17:44:47
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 300FE087602415
Coding: 0000002
VCID: 306FDC8CA3238A9E38D
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000068687
Subsystem 3 - Serial number: 0123.06.080000000100010121ÿ
Subsystem 4 - Serial number: 010121ÿ
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 218
Mileage: 81927 km
Time Indication: 0
Date: 2013.01.07
Time: 15:15:06
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000152112
Coding: 0088081
Shop #: WSC 02311 785 00200
VCID: 1C37183CDFAB1EFE745
4 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 15
Reset counter: 242
Mileage: 80373 km
Time Indication: 0
Date: 2012.12.18
Time: 20:00:30
Freeze Frame:
Voltage: 14.40 V
00458 - Control Module for Battery Monitoring (J367)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 243
Mileage: 82616 km
Time Indication: 0
Date: 2013.02.04
Time: 19:35:22
Freeze Frame:
ON
Bin. Bits: 00001111
00819 - High Pressure Sensor (G65)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 82805 km
Time Indication: 0
Date: 2013.02.06
Time: 17:46:52
01592 - Air Quality Sensor (G238)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 82805 km
Time Indication: 0
Date: 2013.02.06
Time: 17:46:53
Freeze Frame:
Temperature: 17.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0133121
VCID: 387FE4AC4B5352DE70D
Subsystem 1 - Part No: 4E2 910 113 C
Component: Wischer WWS D3 H60 0440
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00139548
Shop #: WSC 02313
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 81927 km
Time Indication: 0
Date: 2013.01.07
Time: 14:56:09
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 0 km
Time Indication: 0
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 244
Mileage: 82805 km
Time Indication: 0
Date: 2013.02.06
Time: 17:32:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 244
Mileage: 82605 km
Time Indication: 0
Date: 2013.02.04
Time: 17:44:49
Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 2B55CBE04A05E9460DF
No fault code found.
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276W7301043
Coding: 0000001
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI G000AGSª0020
Coding: 0011773
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 82616 km
Time Indication: 0
Date: 2013.02.04
Time: 19:35:17
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
(no units): 25.5
Bin. Bits: 00000000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 E HW: 4E0 959 655 K
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CU000FVKP
Coding: 0431707
VCID: 285F34EC9BF3C25EE0D
Subsystem 1 - Serial number: 63328RB403CA82E9-
Subsystem 2 - Serial number: 63428RB403CA8336O
Subsystem 3 - Serial number: 63528RB403CA82DB$
Subsystem 4 - Serial number: 63628RB403CA84F8+
Subsystem 5 - Serial number: 63729RB403F2D15CY
Subsystem 6 - Serial number: 63829RB403F2D12AU
1 Fault Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 204
Mileage: 82805 km
Time Indication: 0
Date: 2013.02.06
Time: 17:32:22
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H05000 Serial number: 90055081590170
Coding: 0112141
VCID: 26433AD491E7D42ED21
Component: E0221 H02 0030
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 218
Mileage: 81928 km
Time Indication: 0
Date: 2013.01.07
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 244
Mileage: 82605 km
Time Indication: 0
Date: 2013.02.04
Time: 17:44:45
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 J HW: 4E0 920 951 J
Component: KOMBIINSTR. VDO H84 0620
Revision: D03 Serial number: AUDID3H5100079
Coding: 0032423
Shop #: WSC 00022 210 87575
VCID: 2C57C8FC8F0BEE7E045
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 G
Component: Heizgeraet H08 0140
Revision: 0000000C Serial number: 00000009013887
Coding: 0000001
VCID: 1A3B1E24D59F60CE669
3 Faults Found:
00664 - Fuel gauge
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 C
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1000D08316811E
Coding: F5F9DFFF747E0E00
Shop #: WSC 00022 210 98720
VCID: 2D51C5F8B411E77613B
4 Faults Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 64
Mileage: 74849 km
Time Indication: 0
Date: 2012.04.18
Time: 10:58:24
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 81927 km
Time Indication: 0
Date: 2013.01.07
Time: 14:56:09
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 222
Mileage: 82383 km
Time Indication: 0
Date: 2013.01.27
Time: 17:36:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 244
Mileage: 82605 km
Time Indication: 0
Date: 2013.02.04
Time: 17:44:44
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8472511
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000073930
Coding: 0000000
VCID: E1C9E9C83849F316673
1 Fault Found:
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 L HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 6340
Coding: 0015510
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063338
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 244
Mileage: 82604 km
Time Indication: 0
Date: 2013.02.04
Time: 17:44:47
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H52 1050
Revision: 00000000 Serial number: 364F-087799320
Shop #: WSC 00402 210 92240
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000815400064
Coding: 0035972
VCID: 1D311538C4B117F683B
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 244
Mileage: 82604 km
Time Indication: 0
Date: 2013.02.04
Time: 17:44:00
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0001107
Shop #: WSC 00022 210 175147
VCID: 2E53C2F4B9179C6E2A1
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H01 0020
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F25.06.0800H010003C910318ÿ
Subsystem 4 - Serial number: 910318ÿ
1 Fault Found:
02852 - Indicator Lamp for Lane Change Assistance (K232)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 244
Mileage: 82804 km
Time Indication: 0
Date: 2013.02.06
Time: 17:32:20
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 F
Component: Türsteuer.FS BRM005 0180
Coding: 0028463
VCID: 204F2CCCF3C33A1EA8D
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 218
Mileage: 81920 km
Time Indication: 0
Date: 2013.01.07
Time: 14:56:34
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: W040806230149
Coding: 0004349
VCID: 2B55CBE08A05E9460DF
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
6 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 244
Mileage: 82605 km
Time Indication: 0
Date: 2013.02.04
Time: 17:44:48
02740 - Bulb for Tail Light 2; Left
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 218
Mileage: 81928 km
Time Indication: 0
Date: 2013.01.07
Time: 00:02:32
02741 - Bulb for Tail Light 2; Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 218
Mileage: 81928 km
Time Indication: 0
Date: 2013.01.07
Time: 00:02:33
01501 - Bulb for Blinkers; Rear Left (M6)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 218
Mileage: 81928 km
Time Indication: 0
Date: 2013.01.07
Time: 00:02:46
01505 - Bulb for Blinkers; Rear Right (M8)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 218
Mileage: 81928 km
Time Indication: 0
Date: 2013.01.07
Time: 00:02:47
02200 - Communication Wire to Taillights
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 218
Mileage: 81928 km
Time Indication: 0
Date: 2013.01.07
Time: 00:22:22
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000112878
Coding: 0000023
Shop #: WSC 00762 210 89838
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000026930
Coding: 0010101
VCID: 1E331234C9B70CEE9A1
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 244
Mileage: 82604 km
Time Indication: 0
Date: 2013.02.04
Time: 17:44:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 F
Component: Türsteuer.BF BRM005 0180
Coding: 0028463
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 218
Mileage: 81920 km
Time Indication: 0
Date: 2013.01.07
Time: 14:56:34
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0001031
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000018
VCID: E9D9F1E8C079BB56BF3
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396F6087598178
Coding: 0000001
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 D HW: 4E0 919 148
Component: R78 TVHybridDVB 0440
Revision: R0H06000 Serial number: 76300801626202
Coding: 0000003
1 Fault Found:
02283 - Video Connection to Output [End Unit]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 244
Mileage: 82791 km
Time Indication: 0
Date: 2013.02.06
Time: 12:46:18
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000011478
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2806231936
Coding: 344530393135313035412056413032383036323331393336
1 Fault Found:
02255 - Voltage Measuring Lead from Vbat
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 218
Time Indication: 0
Date: 2013.01.07
Time: 15:14:55
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028463
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 218
Mileage: 81920 km
Time Indication: 0
Date: 2013.01.07
Time: 14:56:34
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 244
Mileage: 82448 km
Time Indication: 0
Date: 2013.01.30
Time: 08:21:42
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000806200262
Shop #: WSC 12336 024 394758
VCID: 3663EA944147A4AE621
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J86101T
Coding: 1020402
VCID: DCB7D83C1F2BDEFE345
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 218
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 218
Mileage: 81927 km
Time Indication: 0
Date: 2013.01.07
Time: 14:56:10
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0028463
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 218
Mileage: 81920 km
Time Indication: 0
Date: 2013.01.07
Time: 14:56:34
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08740817105534
Coding: 0221008
VCID: 234523C0E2D52106B5F
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H11 0960
Revision: 00H11000 Serial number: 00000007581143
Coding: 0060001
End ---------------------------------------------------------------------
The warranty is for all electrical and mechanical components, but does not include wiring faults and at £90 ($150) per hour labour charge, I don't want too high a bill from them.
But that's a ton of error codes. How is the car, error warnings all the time? Looks like nothing is working properly.
There's just too many errors with a lot of them being supply voltage, so my bets are that it's the battery on the way out, or something to do with the main power system. Nothing else in the car could have such a wide reaching effect on unrelated systems.
Or you've bought a car that's been in a flood
As a new VAG COM owner, on the first scan you will tend to see tons of stuff, more so even if you were straightening out issues first. Endless power system lower limit exceeded stuff for example in a number of modules that can be as simple as leaving ignition on a lot while playing with the car. Thus, I would just save/capture the whole set, then clear all and see what comes back pronto, plus what incremental codes you have in a few days. Then you have the real areas to focus on for your service appointment. At a minimum clear all the under voltage ones just to get rid of some underbrush; I routinely do that when I know they are just false alarms from leaving key on, lights on, etc.
I believe Audi guys will do the same, but it is still good for them to see it as it is. I don't know how that warranty works. They may be unhappy with somebody messing up with car electronics. Or just use that as an excuse.
This is the message I get:-
Coding: 0431707
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 82821 km
Time Indication: 0
Date: 2013.02.07
Time: 08:31:06
Any clues as to what to do to reset it, (I am certain that everything was put back together correctly when I re-assembled the dash panel.
Thanks, Alan
