Fuel Pump Fuse Location
So I'm going to clean the carbon out of my intake valves as I did on my S6. I looked up the fuse location (31 on right side front passenger door) and I found there is no fuse in that slot. Where is it? My manual and car panel say the same thing. Where is the fuse on a 2007 A8 with a 4.2?
Someone has to know how to do this. I know there are two fuel pumps, how do i shut them off so when i bump the starter to rotate the engine for valve cleaning I don't get fuel sprayed everywhere?
Not sure if this is what youi need...but i got this from a maintanance manual
Not sure either.. But
It does say Fuel Pump relay (J17) and Fuel Pump 2 Relay (J49).
sounds like pump 1 and 2... let me know what you find out.. now I am curious..
I didn't end up pulling the relays, I decided to just disconnect the fuel pumps. I didn't want to risk having fuel shoot all over when I opened the driver's door to get in and turn the car over. My solution worked perfect and only took about 5 minutes to do.
Man, my car is running a lot stronger and smoother after I cleaned a 100K of carbon out of the intake valves.
wpwp (10-29-2023)
Fuse box location fuel pump relay J49
I looked in the trunk where the battery and dvd navigation system is located. Also, I removed the covering for the spare tire well. Thats where I gound the two fuel pumps. Can someone take pics of exactly where the fuel pump relays are located? Thank you.
I hope you received my message. I really need your help. I need the part number for fuel pump relay 2 in the luggage/trunk compartment located at #3, next to the battery. Please when you get this message email me: stm92576@gmail.com
Picture of relay with part number
carl viking
36
04-27-2020 01:17 PM
S4intheOC
09-08-2015 12:12 AM
FedericoDC
2.0T FSI Discussion
09-05-2015 11:45 AM
