Gruven Intake Links
Old Feb 27, 2012 | 01:03 AM
AusA8's Avatar
Default Gruven Intake Links
After waiting for the dollar to go back up, I ordered the Gruven intake links.
10 days later arrived and installed...
Well made parts and took a few mins to install.
System works again - yay, but didnt fix the engine vibration that I've got. I suspect that I have an engine mount or misfire issue.
Couldn't really feel any difference in torque but will check again tomorrow when I can open her up a bit more than on suburban streets.
Thanks to folks on here for the referral!
Cheers
Old Feb 27, 2012 | 06:19 AM
K9COP's Avatar
Forgive my ignorance (I have lots of it...) but what do these do please?
K9
Old Feb 27, 2012 | 11:57 AM
transporter2004's Avatar
K9
correct me because I am probably wrong, but I think they are located on the rear of the intake and have an effect on the air flow during fuul throttle acceleration??? The stock pieces are plastic and crack.
I'm not sure.
Mishar probably knows
Old Feb 27, 2012 | 12:24 PM
mishar's Avatar
Tech Guru
Only correction - they are on the front of the engine.
Old Feb 27, 2012 | 05:35 PM
K9COP's Avatar
Gotcha, thanks guys.....
K9
Old Feb 28, 2012 | 12:35 AM
AusA8's Avatar
And another slight addition.
It's not just wide open throttle (WOT) but they also work at lower engine speeds also. They are actuating arms for the variable intake manifold. The intake length are adjusted depending on rpm to give better performance at not only the top end of the rev range, but also improved torque at lower and mid range rpm. SSP 282 gives a brief overview of this arrangement if you want more info.
And, after driving it today, it can state that there is a marked improvement in low end torque!!
Old Feb 28, 2012 | 06:18 AM
mishar's Avatar
Tech Guru
With broken link does it stay in closet position under some spring or it is loose?
Old Mar 1, 2012 | 02:27 AM
AusA8's Avatar
The way it should work is as follows:
With engine off, the arms are under spring tension and therefore the internal flap allows the 'short' intake length. Upon starting and engine at idle, the vacuum pulls the arms down thereby making the length 'long'. It stays like this till 4,480rpm when the solenoid trips and releases the vacuum, thereby allowing the shorter run.
In 'long' length, better torque at lower rpm, in 'short' length after 4,480rpm, better power.
For me, with broken linkage, I had one cylinder bank running in 'short' length all the time, hence under 4,480rpm I had one bank in 'long' and in 'short', effectively inhibiting low end torque. That's now fixed and whilst it's not a massive difference in performance, I reckon I can "feel" it.
Interestingly, whilst rummaging through the SSP, I also found that on WOT when revs swing past 3,000rpm, another flap opens in the air box to take additional air from the engine compartment! So darn complex!! But oh so nice!!
Old Mar 1, 2012 | 03:47 AM
Edd W's Avatar
I suppose theory is that above 3000rpm and WOT any hot air will have been purged from around the engine anyway - unless you are hading backwards at a great rate of speed anyway!
Old Mar 1, 2012 | 04:13 PM
mishar's Avatar
Tech Guru
You are right. I had to check it on my car because I would never design it like that. As it is if anything is wrong with the system (vacuum leak, leaky valve, broken actuator or lever...) you loose low end power. If it is just opposite, under springs long intake, you would loose high end power and in most cases no harm at all.
