Headlight marker bulb blown. Does anyone know the bulb number?
One of my headlight marker bulbs blew this past weekend and I'm looking to replace it. I have an '04. Anyone know the bulb number? Also, it appears as though access is somewhat limited at the rear of the headlight assembly. The access panel seems to be blocked by the air box on the right side and a fluid reservoir on the left. It seems as though these need to be removed to gain proper access.
From what I have observed, you would have to have hands the size of a chimpanzee's, matching dexterity and sufficient strength to change that bulb? That must be it! I will buy a chimp and train it! Folks I am sorry to have bothered you... I think I solved my own problem.
On a more serious note... any help you can afford would be greatly appreciated.
...and Happy New Year to all!
What is a headlight marker bulb? Holy cow, these things are difficult to repair
I mean remove the power steering resevoir? Remove the wheel liner? I have posted both below.
From the Bently:
Audi > D3 > 2004-2005
Electrical Equipment
94 - Headlamps, servicing - USA and CanadaAuxiliary parking light bulb, replacingRemoving
Switch off ignition and remove ignition key.
Turn light switch into "0" position.
Left headlight:
Remove power steering fluid reservoir .
Right headlight:
Remove upper section of air filter housing .
All:
Disengage retaining tabs - arrows - and remove high beam housing cover from headlight housing.
Release parking light socket by pressing grip on socket down - arrow 1 - .
Pull parking light socket out of headlight housing - arrow 2 - .
Remove parking light bulb - 1 - from socket - 2 - .
Installing
Install in reverse order of removal, observing the following:
Insert new bulb into socket, do not touch glass cone with bare hands.
Press socket into reflector until it is felt to engage.
Close housing cover.
94 - Headlamps, servicing - USA and CanadaTurn signal indicator bulb, replacing Removing
Activate vehicle lift mode Suspension, Wheels, Steering - Repair Group 43 .
Remove appropriate front wheel.
Remove appropriate front wheel housing liner Body Exterior - Repair Group 66 .
Loosen locking bolt - 1 - a few turns.
Release retainer tabs - arrows - and detach low beam housing cover from headlight housing.
Remove bulbs - arrows - from housing.
Disconnect connector at bulb.
Installing
Close housing cover and secure with screw.
Install front wheel housing liner Body Exterior - Repair Group 66 .
Deactivate vehicle lift mode Suspension, Wheels, Steering - Repair Group 43 .
From the Bently:
Left headlight:
Right headlight:
All:
Installing
Installing
There's 2 guys still alive out in San Francisco that like visting the zoo with sling-shots..
maybe they could visit the monkey cages instead. Oh, my mistake, they (the two guys) have small brains not small hands. Sorry, my bad!
Moral of this story...don't ride around with headlights on during daylight hours, even if it's
safer and then trade these babies in before the marker bulbs blow-out!! Just kidding! But not laughing either!
2nd Moral: Replace in pairs! The replacement will be much brighter than the one remaining.
Brought to you as a public service from someone who's already got that T-shirt.
Yep, I've checked the Bentley manual procedure out myself in anticipation
of what the procedure entails. IIRC, the procedure was different on road side vs. curbside for one of the sets of bulbs.
The service manual (CDRom) is mandatory if you do any work on these cars yourself. Even changing the oil. First car I ever owned where I could not find the oil filter!
Wait until the next oil change before replacing that burnt out bulb!
VR6eric
A6 (C7 Platform) Discussion
11-28-2018 10:47 AM
golfindaily
05-12-2007 10:27 AM
