How do I do basic setting/adaptation on control head (module 7)
Old Jan 17, 2018 | 11:28 AM
powderlvr's Avatar
Default How do I do basic setting/adaptation on control head (module 7)
Hi everyone,
Could someone please tell me how to fix the following error?
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Control Module Part Number: 4E0 910 732 S HW: 4E0 035 729
Component and/or Version: Interfacebox H43 4610
Software Coding: 0000003
Work Shop Code: WSC 00000 000 00000
Additional Info: 4E0910611 E0380 BedienteilH01 0050
Additional Info: Geraet 00000
VCID: 326BFB26AD3DC6D657-8066
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 59
Mileage: 269437 km
Time Indication: 0
Date: 2018.01.14
Time: 17:52:47
Background: recently I put in a new headlight control module in the 2006 A8L and I followed VCDS instructions afterwards to adapt that new module. The car had sat with a flat-dead battery for several days prior to that repair, so many codes needed to be cleared after I charged it up. But now, all of the sudden, the MMI doesn't show many of the things it used to. For instance I can't raise or lower the car (that menu is gone), the seat heater setting doesn't show on the screen, etc.
Thanks in advance!
Old Jan 17, 2018 | 12:43 PM
JulianHicks's Avatar
Thanks in advance!
This happened to my A8 recently; your Control Head has lost all its adaptations due to dead flat battery. I'm not sure it's meant to but I certainly lost all of my settings and had to reset the Control Head with a little guess work.
You need to reset the Control Head Adaptation channels using VCDS. Look at the Labels folder in the VCDS folders and find file 4E0-910-7xx-07.LBL. Use Notepad or a text editor to print it. Look at the Adaptations section and set the values according to which facilities you have installed in your car. Do this by using VCDS to connect to the Control Head and to change the various channels.
Julian
Petter Stendalen
Audi allroad
Feb 16, 2018 05:44 PM
Eliasv
Audi A3 / S3 / RS 3
Sep 25, 2016 11:00 AM
A8 - 4.2L
VAG-COM Discussion
Jan 6, 2009 04:35 PM
3.0 TDI
Dec 21, 2008 04:36 PM
cbd1
VAG-COM Discussion
May 19, 2007 10:26 PM
