control module error
aturday,24,September,2016,09:25:37:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
Ross-Tech: Home
Mileage:****Repair Order: 02
****************Address 03: ABS Brakes*******Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 AE****HW: 1K0 907 379 AE
**Component and/or Version: ESP MK60EC1***H35 0106
***********Software Coding: 14426012092300FB280B06E590200041B900
************Work Shop Code: WSC 13320 993 45725
**********************VCID: 75E18BB2DC001CEA83-8020
2 Faults Found:
16352 - Control Module - Electrical Error
************014 - Defective
*************Freeze Frame:
********************Fault Status: 01101110
********************Fault Priority: 1
********************Fault Frequency: 1
********************Reset counter: 122
********************Mileage: 71632 km
********************Time Indication: 0
********************Date: 2016.09.05
********************Time: 00:22:24
********************Count: 16391
********************Count: 12
********************Count: 12800
********************Count: 233
********************Count: 44800
********************Count: 0
********************Count: 1792
00538 - Reference Voltage
************012 - Electrical Fault in Circuit
********************Fault Status: 01101100
********************Fault Priority: 2
********************Time: 00:22:27
********************Count: 131
********************Count: 42496
********************Count: 3328
Sunday,25,September,2016,09:44:59:49450
Ross-Tech: Home
VIN: TRUJF28P891011017 License Plate:
Mileage: 71630km-44508mi Repair Order: 250916 2
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 26 42 44 46 52 55 56 62 72 77
VIN: TRUJF28P891011017 Mileage: 71630km-44508miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CAW) Labels: 06J-906-026-CAW.clb
Part No SW: 8P7 907 115 B HW: 8P0 907 115 J
Component: 2.0l R4/4V TFSI 0020
Revision: A7H06--- Serial number: AUX7Z0H9FN20CX
Coding: 011B00031C070060
Shop #: WSC 01236 758 00200
VCID: 387F42864B92A18258-806C
2 Faults Found:
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 61
Reset counter: 255
Mileage: 71632 km
Time Indication: 0
Date: 2016.09.05
Time: 00:26:50
Freeze Frame:
RPM: 757 /min
Load: 22.7 %
Speed: 0.0 km/h
Temperature: 67.0∞C
Temperature: 33.0∞C
Absolute Pres.: 980.0 mbar
Voltage: 13.589 V
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 26.0∞C
Temperature: 27.0∞C
Voltage: 12.192 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 051 R HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1926
Revision: 04844002 Serial number: 00000911230366
Coding: 0000020
Shop #: WSC 04926 001 00001
VCID: 224B80EEFD0EDB5296-8076
1 Fault Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 255
Reset counter: 1
Mileage: 71632 km
Time Indication: 0
Date: 2016.09.05
Time: 00:17:20
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Shop #: WSC 13320 993 45725
6 Faults Found:
01279 - Longitudinal Acceleration Sensor (G251)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 71632 km
Time Indication: 0
Freeze Frame:
Count: 7
Count: 14
Count: 12800
Count: 211
Count: 43264
Count: 0
Count: 0
Count: 65024
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 71632 km
Time Indication: 0
Freeze Frame:
Count: 7
Count: 14
Count: 12800
Count: 267
Count: 43264
Count: 0
Count: 0
Count: 65024
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Mileage: 71632 km
Time Indication: 0
Freeze Frame:
Count: 7
Count: 14
Count: 12800
Count: 233
Count: 43264
Count: 0
Count: 0
Count: 65024
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 71632 km
Time Indication: 0
Freeze Frame:
Count: 7
Count: 14
Count: 12800
Count: 131
Count: 43264
Count: 0
Count: 0
Count: 65024
01130 - ABS Operation
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 122
Mileage: 71632 km
Time Indication: 0
Date: 2016.09.05
Time: 00:17:47
Freeze Frame:
Count: 7
Count: 15
Count: 12800
Count: 113
Count: 33280
Count: 0
Count: 0
Count: 64512
01542 - Yaw Rate Sensor (G202)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 71632 km
Time Indication: 0
Date: 2016.09.05
Time: 00:17:22
Freeze Frame:
Count: 7
Count: 13
Count: 12800
Count: 4280
Count: 0
Count: 0
Count: 0
Count: 63232
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BC HW: 8P0 820 043 BC
Component: KlimavollautomatH03 0110
Revision: 290791 Serial number: 8P0820043BC
Shop #: WSC 00000 000 00000
VCID: 6ED3A4DE79562F3242-803A
No fault code found.
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009063671
Coding: E5061F0190141080EF00000A0000000000094E016406000300 A000000000
VCID: 489F32463B72D10228-801C
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 01236
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150573
Shop #: WSC 01236
Address 15: Airbags Labels: 8P7-959-655.clb
Part No SW: 8P7 959 655 HW: 8P7 959 655
Component: SL Airbag 9.43 H01 0020
Revision: 93H01002 Serial number: 003BS000HZFN
Coding: 0021324
VCID: 0603FC7E71E607729A-8052
Subsystem 1 - Serial number: 6332DRB407AA8E2E5
Subsystem 2 - Serial number: 6342DRB407ABC513X
Subsystem 3 - Serial number: 63747RB404778D58Z
Subsystem 4 - Serial number: 63847RB404778BD1Z
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0013111
VCID: 41892F621848E04AEF-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 A HW: 8P0 920 932 A
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2249H006006256
Coding: 0000128
Shop #: WSC 25190 993 98262
VCID: 326B70AEADEE4BD266-8066
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 71632 km
Time Indication: 0
Date: 2016.09.05
Time: 00:17:20
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K0891284B1
Coding: ED817F26000602009100
VCID: 377D41BA468CAEFA51-8062
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18006 Serial number: AUX7Z0H9FN20CX
Address 26: Auto Roof Labels: Redir Fail!
Part No: 8P7 959 255 A
Component: VSG AUDI A3 H14 0100
VCID: 4385256A0254F25AFD-8016
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P7 959 801 C HW: 8P7 959 801 C
Component: Tuer-SG H02 0020
Coding: 0000220
VCID: 428B206E1D4EFB52F6-8016
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
VCID: 2A5B68CE853E0312DE-807E
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 71632 km
Time Indication: 0
Date: 2016.09.05
Time: 00:17:20
Freeze Frame:
Battery Volts: 14.1 V
DU
Temperature: 30.0∞C
Count: 2
Steering Angle: 0.00∞
Count: 1
SteerAng n.Init
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 K
Component: KSG H11 0080
Coding: 189022004238490985254C8ED633
Shop #: WSC 32510 993 57941
VCID: 44872676075AF562C4-8010
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 8P7 951 177
Component: DWA-Sensor H03 0030
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P7 959 802 C HW: 8P7 959 802 C
Coding: 0000220
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000013
Address 56: Radio Labels: None
Part No SW: 8P0 035 195 N HW: 8P0 035 195 N
Component: R Symphony2+ H05 0270
Revision: 00H05000 Serial number: AUZ1Z4H7183640
Coding: 0730202
VCID: 3D71539264B084AA8B-8068
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 8P7 959 811 A HW: 8P7 959 811 A
Component: Tuer-SG H01 0030
Coding: 0000144
Shop #: WSC 01236 758 1012552
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 8P7 959 812 A HW: 8P7 959 812 A
Coding: 0000144
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005044111
Coding: 0001255
Shop #: WSC 32560 993 55978
VCID: 46833C7E3166C772DA-8012
End-------------------------(Elapsed Time: 02:08)-
