How Do You Remove The Trunk Lock/Release?
Just as the title says, I'm looking for some help with how to remove the trunk release assembly. I have this stupid thing about 95% of the way out, but it seems to be caught up on something connected to the lock. Problem is, even with cramming my camera up there and taking pictures, I can't seem to figure out what!
Has any removed this entire assembly? What am I missing? Thank you in advance!
Edit: figured it out.
Make sure you properly connect BOTH cables to the latch assembly when reinstalling. Test the manual key release, inside trunk release **** and electric release (key fob, door or trunk lid switches several times before actually locking the trunk.
Most important is the cable from the manual lock cylinder.
I just replaced my latch the other day as the cold caused it to fail and I don't want to ever deal with it again.
Aside from cleaning some gunk out and re-lubricating, I left the latch assembly alone. I had to remove the assembly containing the lock, trunk release switch, and license plate bulbs. I did have to disconnect the cable to the lock from the latch, which looks like it's going to be a HUGE pain to reconnect. I need to find someone with baby hands to reach up there and get everything buttoned back up!
If you don't see the two bolts, that's because you didn't slide off the black plastic cover from the latch.
This is a classic example of why everyone that does repairs should invest in the service manual for this, and any car they own.
Remove the latch (two 10mm bolts), slide it down and reattach the cable. Simple.
Good point about the manual! I added the Bentley manual to my Amazon cart, but I'm hoping to find a physical copy, if such a thing exists. I don't have Windows XP, and my computer doesn't support it.
