How to remove inner door panel?
I have the outer panel off, trying to gain access to replace drivers mirror. Torn bolts holding perimeter of aluminum panel are out, what else comes off?
Also, look at those door card plastic mount pins. You likely broke a few and now will play hell trying to get back on. BTDT. I always have several on hand for replacements when I pull a door card.
Getting the window in the correct position was the key, one I got the removal bolts lined up, everything else was cake.
Thanks, mirror is replaced, and working! While I was in there I added a bit of sound deadening material and tried to re-wind the soft close cable, which was off. Apparently it is still not right, cause it's not winding now at all. Also lubed the window track, as it was making a creaking noise.
All buttoned up, only one clip broken. I'd like to order a couple more and go back in to attack soft close motor again.
andyb64
57
12-13-2023 05:03 PM
mAgnum8
11-09-2008 07:16 AM
j31izzle
04-18-2007 12:05 PM
Shaun Bowen
10-12-2003 12:27 PM
