instrument cluster keeps turning off while driving
#12
Based on the quiesce 194km before the scan and the low supply voltage I'd say it is battery or wiring related.
The fact that is reboots and the clock resets seems to back this theory up.
What does your battery meter show in MMI ?
If you replace it, the battery management module needs adaption per this how to.
I'm also highly suspicious of the chassis type of 4L0 which is a Q7.
Ok finally got my Vag Com so here are the results:
Sunday,06,November,2011,17:16:20:53686
VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 4L0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 28 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUMV44EX7N022730 Mileage: 45150km/28054miles
Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785
Component: SG ext.Player H09 0850
Revision: 00000000
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 2B5F07B9F39E
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 200
Mileage: 44808 km
Time Indication: 0
Date: 2011.09.03
Time: 00:39:08
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000005784
Shop #: WSC 00000 128 00289
VCID: 2045E0958A58
Part No: 4E0 915 105 A
Component: von VA0 2705210661
Coding: 344530393135313035412056413032373035323130363631
2 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 4
Mileage: 44956 km
Time Indication: 0
Date: 2011.09.17
Time: 00:00:02
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 0 km
Time Indication: 0
Date: 2011.09.17
Time: 00:01:16
Chassis Type: 4L0
Revision: 00000000
Coding: 010000
VCID: 2B5F07B9F39E
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 200
Mileage: 44808 km
Time Indication: 0
Date: 2011.09.03
Time: 00:39:08
VCID: 2045E0958A58
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 44956 km
Time Indication: 0
Date: 2011.09.17
Time: 00:00:02
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 0 km
Time Indication: 0
Date: 2011.09.17
Time: 00:01:16
#13
Hi
I did replace the battery because it kept dying on me but I didn't get an OEM just one from Battery World that had same specs.
It could be the previous owner replaced the module? I am the 3rd owner. That could explain why its messing up they used the wrong part
#14
Looks up all the different fault codes you're getting here: http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
I had a similar problem in my A6 a while back where the LCD display between the two gauges would not turn on. After scanning with VAG-COM I saw + others.
01317 - Instrument Cluster (J285): No Communications
Possible Causes:
CAN-Databus Wiring/Connectors from/to Instrument Cluster (J285) faulty
Fault(s) stored in Instrument Cluster (J285)
It was the "Fault(s) stored in Instrument Cluster (J285)" that got my attention so once I addressed the other issue and cleared the fault code associated with my other issue (it was a simple relay problem) the instrument cluster started working again without issue.
Possible Causes:
#16
Possible Causes:
#17
Looks like the CAN Gateway is from a Q7:
Whether this is a problem or not I don't know.
Preliminary research shows other D3's have this, and may have something to do with being backup camera aware.
See here https://www.audiworld.com/forums/sho....php?t=2616555
I think cebo0650 is onto it with the J285.
Missed that in my first run through of the scan.
Code:
Address 19: CAN Gateway Labels: 4L0-910-468.lbl Part No SW: 4L0 910 468 HW: 4L0 907 468
#18
J285 has an extreme amount of faults, seems to me that would be the issue.
This may help to shed some light:
http://www.audi-portal.com/en/diagnostic/ecu_10831.html
RE: 4L0 module, the VIN checks out for an A8 so they may be interchangeable, but I would be surprised if they were.
