Let's play find the engine Code
Old May 27, 2020 | 01:34 PM
gbmarc's Avatar
Default Let's play find the engine Code
Audi Jeopardy: 2007 A8 4.2 The service book is missing. The option sticker in the trunk is missing. There is a green sticker on the left rear timing cover that is totally blank. How do you find the engine code?
My answer was to use the manual. It says it's stamped on the LHS where the engine joins the gearbox and it shows the spot in a diagram. However, the diagram doesn't look like my engine and anyway, good luck finding anything back there under a dozen pipes and widgets. Next I took the part number stamped on the rear timing cover and found that it was applicable for only BVJ engines. Then I took the part number stamped on the cylinder head and that too was for BVJ engines. Unless anyone has a better answer, that's gonna be my final answer!
(How hard could it be to just stamp in somewhere you could actually see it? "What?" you say "and make it easy?" Oh, I forgot. This is an Audi.
(I have a great location for it. How about on the inside of the pinch bolt shaft?
Old May 27, 2020 | 11:16 PM
NightOwl's Avatar
Take a look at the sticker in the trunk, under the cover next to the spare wheel.
Old May 28, 2020 | 05:03 AM
Giovanni Giovino 6.0+6.0TT's Avatar
That's the second thing listed as missing right in the beginning of the post....
Old May 28, 2020 | 05:18 AM
uberwgn's Avatar
Super Moderator
GB, I looked up an oil filter for your car and BVJ is the only engine code they show for the 4.2L.
Old May 28, 2020 | 06:14 AM
Brown Water's Avatar
Add your VIN to the Vin Decoder thread. The response will have your engine code.
Old May 28, 2020 | 04:21 PM
fjord's Avatar
This.
mrprism133
9
Jan 29, 2016 02:15 PM
drageron
12
Apr 8, 2006 09:27 PM
1.8TForMe
Jun 15, 2005 02:13 PM
odelay12v
Jun 15, 2005 10:23 AM
AZSantorin
Apr 22, 2003 03:17 PM
