Level Control
So I first parked the car in the garage on level ground. Turned the ignition on and inserted the Vag cable into the obd2 scan port under the driver's left side knee cover area. I made sure to connect the cable to the car first, then snake the cable out of the driver's side window where my laptop was. I then connected the cable to the laptop.
Started up Ross-Tech's Vag Com software, selected the select control module buton. Then I clicked on the chassis tab at the top row of tabs. In this menu, I selected controller 34 - Level Control. The stock code read like this: (Basic Setting)
0015510
the only numbers that matter are the two fives. Each integral drop in number corresponds to a 5mm drop. For example, I wanted a 20mm front and 15mm rear drop so I entered:
0011210
After entering and saving I closed the Vag com - removed the vag cable and turned off ignition. I restarted the car (engine turned on) and reconnected the cable to the port.
I then went back to controller 54 - level control. Over on the right side of buttons on the Vag-Com panel, there's a button called security access - which I clicked. I then entered the number 31564. Important: Once you enter this, you need to complete the adaptation from beginning to end or else the car will not adapt to your new settings and it will go into a limp mode for the suspension.
After entering the security code, I went to teh adaptation button. There are five channels:
01 Front Driver
02 Front Passenger
03 Rear Driver
04 Rear Passenger
05 Save
First select 01. Press return. The car will then lower and raise its suspension. After its complete and the vag-com status windows says okay to enter - go to the test value window on the left side of the test button. Measure the center axle to the bottom of the fender lip - make sure to measure in millimeters. Enter this value in the test value window and press enter. Then click on save. Do this same thing for channels 02, 03, and 04. When you are done, go to channel 05 and enter 1. This saves the adaptation. Exit out of the Vag-Com.
Now get into the car and then drive back 15-20 feet and drive forward back to teh same spot you were before. Repeat the adaptation and you should notice that the values in the read section should be fairly close to what you measure. If not, continue to adapt until its right.
I have to measure again, but my car went down about 20mm in the front and 15mm in the back like I wanted to... but I'm still adapting. I'll do it again tomorrow to make sure its right.
It excepts 388mm but that's not what I measured. No wonder it's not levelled when done. In the process my compressor is working big overtime pumping it up again and again. I just wonder what bright mind programmed it so that it has to be started all over again when it doesn't accept a measured value. Must be that famous German software engineering. Or may be software is out of expertize.
Leave it be for now. First thing tomorrow, reset to factory settings. Then try it once or twice and that's it. You only get a few chances at a time, so make sure you get it done right from the gitgo.
Cheers.
Edward
