MMI Stuck In Bootloader
Old Oct 13, 2011 | 08:04 AM
  #11
05SilverA8's Avatar
Default Bluetooth
Remove the footrest with a Torx (30?). Move seat to all the way back position. Remove plastic moulding and then lift up the drivers side carpet. It is in a black box under the carpet. See attached photo.
Old Oct 13, 2011 | 10:24 PM
  #12
haloguy628's Avatar
There is a TSB addressing repair of the Bluetooth module before installing the 4610 update using the CD-1 from the 4610. If the FW and SW are mismatched and you attempt to update to 4610 it may fry the BT module and it has to be replaced. BTW the BT module is Handyvorb in German.
Here, I found the TSB.
RVU - Repairing telephone preparation
Old Oct 14, 2011 | 09:16 AM
  #13
subit0's Avatar
Default Telephone RVU TSB
Owners have reported fried or partially-fried BT modules as a result of previous MMI upgrades (it was 3360 that zapped mine). I believe that it only happened to some BT modules, that were likely installed on 2006 and early 2007 MY vehicles (A8's, but also some Q7's). The TSB specifies a replacement BT module, part # "4F0 910 336 H", and says " The replacement phone module will already have the correct firmware and software version", so you shouldn't need to perform the CD#1 "FW and SW upgrade" of 4610 if you install a new BT module (rev H or later).
It's a pity that the Service Advisors at my local dealership didn't check to see that my car qualified for this repair while it was still under warranty (they only check if the owner complains about a problem, and I didn't notice that my BT was partially broken until after my warranty expired).
Old Oct 14, 2011 | 03:48 PM
  #14
Mills00013's Avatar
Well it already appears that the 3360 update fried the module. The Handyvorb2 that was appearing in my most list is no longer appearing, instead being replaced by the generic hex identifier (0x0FFFFFFFF or whatever). Do you think that the 4610 upgrade might bring it back to life?
I'm really just ready to replace it. I dont think I have much of a chance. Can anyone find me a part number on the bluetooth module?
Old Oct 15, 2011 | 08:18 PM
  #15
subit0's Avatar
Default BT module part #
No, if your BT phone module is fried, the 4610 upgrade CD#1 will detect this and not run at all (i.e. no FW or SW upgrade to the BT module). Your only option is to replace the BT module.
The part # is listed in my previous post (above).
Old Oct 22, 2011 | 09:53 AM
  #16
Mills00013's Avatar
So I've resolved all of my issues except for the amplifier clicking on and off. This now happens every 30 seconds to a minute and the whole sound system will shut off for about half a second. The MMI doesn't close, but the info display in the gauge cluster does black out the radio portion at the top for that split second.
I thought that it was an issue with the battery regulator, but I just purchased an audi battery and recoded the regulator and it is still doing it. Does anyone have any idea which component might be bad or what the issue here could be?
Vag com does tell me that its seeing component protection active on something, but I dont know what. The error is coming up when module 17 (instruments) is scanned.
Old Oct 22, 2011 | 05:25 PM
  #17
greenz's Avatar
Originally Posted by s4master1
it has all the symptoms of water damage in one of the units, this is very common on the Q7, water gets under the carpet and damages the phone unit causing erratic sound operation and jamming the fiber optic network.
you can run a test thru the system and it will tell you what is not responding properly.
s4master can you elborate more on this. I have an d4 A8 and the 'cowl' got clogged up which caused water leakage onto my rear pass carpet and drivers carpet. Now my MMI is in constant reboot with only the "Audi MMI" display poppin up every 10 seconds after performing a hard reboot 'Tel','****','Right button above ****' Dealer whats $500 just to diagnosis thinkin i can get the parts cheaper and just ask them to replace the specific part. Any thoughts. in the past month it works liked 1 / 2 times
Old Oct 22, 2011 | 05:40 PM
  #18
greenz's Avatar
correction d3 gen. for some reason i can't edit the post
Old Oct 23, 2011 | 11:17 AM
  #19
greenz's Avatar
Here is a Vag Com Diagnostic that the $tealership let me have i copied the ones that related to the MMI
Base: V19.00.00
Audi: V19.32.00
AUX64X 1.171
4E0910611
E0380 BedienteilH01
Dealer Number 00000
4E1919612H
000
0050
1 Event Detected
00384 011
Optic Data bus
Open Circuit
Sporadio
Priority 5
Malfunction Occurrence 165
Drive Cycle 142
19- Data Bus Onboard Diagnostic Interface Gateway
4E0910468A
Gateway H07
Coding long
Dealer Number 03106
4E0907468C
0030
2 Event(s) Detected
00384 011
Optic Data bus
Open Circuit
Sporadic
Priority 5
Malfunction O 105
Drive Cycle 142
00463 004
Digital Sound System Control Module – J525
No Signal/ Communication
Sporadic
Priority 3
Malfunction Occurrence 2
Drive Cycle 110
37 - Navigation System
4E0910887K
MNS US H44
Dealer Number 03109
4E0919887C
000
0570
1 Event(s) Detected
00003 014
Control Module
Faulty
Priority 5
Malfunction Occurrence 52
Drive Cycle 0
Old Oct 24, 2011 | 06:39 PM
  #20
Mills00013's Avatar
I'm completely up and running with the exception of my bluetooth module (still being fried in the 3360 update apparently.)
I removed the bluetooth module today and replaced with a MOST optical loop and lo and behold, the entire system works like magic! Thanks so much to everyone for their help! I now have a kick *** W12 for only a fraction of the price!
Does anyone know of a cheap place to get a replacement bluetooth module? The product code on it is 4E0862335. You guys rock!
