MMI update not working
TIA,
Tom
What happened with Disc 1? Does your CD changer work flawlessly? Are you stacked in update or MMI still works with old version?
Strangely after I posted that I tried again to advanced-search for "MMI update" and it worked! I got 63 results IIRC in our D3 forum. none touched on this particular problem.
When I put in disc 1 I get "Reading Meta Info"..., then after about five seconds "no valid update cd found". Tried many times, even tried inverting the discs to be certain they loaded the way I thought they should. (it says "no Disc" when they go in upside-down).
Disc #2 says "Metainfo.txt not found".
I also tried loading both at once.
My cd changer works well, yes; I tried loading a CD into it to check again and it worked fine. I have unloaded all other CDs and I have the battery charger hooked up, too. Car key is off (I tried it with it on, too, no go).
I'm worried I am trying to jump too many SW updates... my current version is 01.5.0 0316; I didn't even have the clock on the bottom of the MMI screen. Anyone care to loan me their old, old SW update CDs?
The P/N is correct on both discs.
Also, since your vehicle is a MY 2004 did you upgrade to the (minimum) of Navigation DVD Version 5? I saw somewhere in the install instructions that was needed in order to do the MMI update.
