Please help interior lights and dash lights randomly turning on and off
This problem started about a month ago and has gotten progressively worse. The interior lights flicker on and off the heater will turn on and off by itself the gauges will go black and come back on like you turned the car off and back on wondering if this sounds like what would be an ignition switch issue I have a good battery alternator is charging just curious if anybody is had an issue like this. I will get error messages that say tire inflation system defective but is actually working all the chimes go off as if you were starting the car again.
Search for the 50-100 posts where issues like this come up. First place to check for flaky electrical on a D3 is battery. Probably 80% or more are resolved there as a rough approximation.
How old is battery?
Have you had it tested?
How do you know it is good, if that is what you are saying/suggesting? As in, not just a voltmeter read to be clear, but load tested too.
What codes does car have in the power management area? As in, with a VW/Audi type tool like VCDS or the app ones but not a generic OBDII scan tool that won't help here.
How old is battery?
How old is battery?
How old is battery?
I replaced the battery about a month ago. I have load tested it with a snap on toaster style load tester and a digital version and it loads tests good. When idling I have 14.3 volts and KOEO I have 12.4. I have a shop and work on cars but mostly LS based Chevy performance stuff so his Audi is pretty new to me I love the car just need a little direction. I have a launch brand scanner which so far I’ve been able to re register the battery and pull codes but gives me a bunch of codes and there not what I’m typically used to reading. It looks very similar to what I see listed on here when reading other posts. Maybe I can screen shot the list it populated and post it and see what comes of hat thanks for your help.
hi there to all im a newbie too can you guys help me out with this scan result i have a problem with the brakes feels like there is no booster power under heavy traffic also the lights flickering inside , and i had a crash and mi front sensors are not working thanks alot .
this is the firs scan
Monday,17,September,2018,17:06:36:16946
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
Ross-Tech: Home
VIN: WAUAM64L88D052431 License Plate:
Mileage: 120000km-74564mi Repair Order: kike q7 1st
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 1E 28 36 3C 42 46 47
4F 52 55 56 61 62 6C 6D 6F 72 76 77
VIN: WAUAM64L88D052431 Mileage: 120000km-74564miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4L1 910 401 HW: 4L0 907 401
Component: 3.0L V6TDI G000AG 0020
Revision: --H05--- Serial number:
Coding: 0010779
Shop #: WSC 19400 993 14628
VCID: 60CFC6B6B3019146F1-8034
2 Faults Found:
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 120004 km
Time Indication: 0
Date: 2007.09.04
Time: 15:30:19
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 12.08 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 120004 km
Time Indication: 0
Date: 2007.09.04
Time: 15:30:19
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 12.08 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Readiness: 0 0 1 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FS HW: 09D 927 750 FS
Component: AL 750 6A 1000
Revision: 00H64000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 0407EA2647592D66B5-8050
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0099473
VCID: 29599B9280BB100EE6-807C
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 119930 km
Time Indication: 0
Date: 2007.09.04
Time: 03:33:25
Freeze Frame:
Count: 64
Count: 65
Count: 128
Count: 39936
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601501000253
Coding: 0000131
VCID: 63C5C9BAA2178A5EEC-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H46 0080
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 732 G HW: 4E0 035 729 A
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 387B$087567527
Coding: 0002004
VCID: 2D516F82B4530C2E0A-8078
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001836152
Subsystem 3 - Serial number: 0106.05.110000000100010535ÿ
Subsystem 4 - Serial number: 010535ÿ
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 121
Reset counter: 40
Time Indication: 15
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 B HW: 4L0 820 043 K
Component: KLIMABETAETIGUNGH07 0030
Revision: 00---013 Serial number: 00000000154982
Coding: 0131158
VCID: 234589BAE297CA5EAC-8076
1 Fault Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 238
Mileage: 105273 km
Time Indication: 0
Date: 2017.07.08
Time: 12:36:56
Freeze Frame:
Temperature: 35.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0113101
VCID: 306F76F6A36161C621-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H15 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00150059
Shop #: WSC 31414
5 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 116576 km
Time Indication: 0
Date: 2018.04.01
Time: 07:42:00
01497 - Bulb for Blinkers; Front Right (M7)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 117192 km
Time Indication: 0
Date: 2018.04.27
Time: 18:04:00
01834 - Bulb for Side-Blinkers; Left (M18)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 2
Fault Frequency: 3
Reset counter: 238
Mileage: 119968 km
Time Indication: 0
Date: 2007.09.04
Time: 08:19:00
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 238
Mileage: 116576 km
Time Indication: 0
Date: 2018.04.01
Time: 07:55:00
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 116620 km
Time Indication: 0
Date: 2018.04.02
Time: 16:09:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 B HW: 4L0 035 110
Component: MP3-Changer H45 0390
Revision: 00045002 Serial number: AUZ5ZBH8300441
Shop #: WSC 00000 000 00000
VCID: 1E33B84EC9F5E7B683-804A
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH42 0230
Revision: 03H42000 Serial number: 00399D043X7
Coding: 0014129
VCID: 2E53688EB955773633-807A
Subsystem 1 - Serial number: 6332QSME5249095FO
Subsystem 2 - Serial number: 6342QSME503308375
Subsystem 3 - Serial number: 6352QSME4D191F59Y
Subsystem 4 - Serial number: 6362QSME501617255
Subsystem 5 - Serial number: 63734SME4709395D8
Subsystem 6 - Serial number: 63834SME50690F0D7
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90026080250104
Coding: 0012142
VCID: 275D9DAA96AF267EF0-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 930 T
Component: KOMBIINSTR. M73 H22 0240
Revision: 00000000 Serial number: 73Y32ZD28
Coding: 3649158
Shop #: WSC 10059 993 999999
1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 18
Mileage: 119913 km
Time Indication: 0
Date: 2007.09.02
Time: 23:08:28
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 E
Component: Heizgeraet H08 0090
Revision: 0000000D Serial number: 00000009014264
Coding: 0000001
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 C
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1000D07A068174
Coding: F5FBFE7774120200
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 D HW: 4E0 035 785
Component: SG ext.Player H15 0830
Revision: 00000000
Coding: 010000
VCID: 29599B9240BB100EE6-807C
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 C
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---009 Serial number: 00000000150461
Coding: 0000006
VCID: 68DFDE965B31E90639-803C
2 Faults Found:
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 80
Reset counter: 255
Mileage: 91642 km
Time Indication: 0
Date: 2014.05.26
Time: 14:06:06
01320 - Control Module for Climatronic (J255)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 103084 km
Time Indication: 0
Date: 2017.05.21
Time: 21:38:26
Freeze Frame:
ON
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082946
VCID: 61C9C3B2B80B984EFE-8034
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH10 0130
Revision: 00H10000 Serial number: 6PZ 009 014-00
Coding: 0000001
Subsystem 1 - Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H08 0130
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F28.01.0800H0800000010112ÿ
Subsystem 4 - Serial number: 010112ÿ
1 Fault Found:
02850 - Control Module 2 for Lane Change Assistance (J770)
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 86580 km
Time Indication: 0
Date: 2016.03.11
Time: 14:42:19
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0150
Revision: 00-00000
Coding: 0002763
VCID: 2F6D758ABE5F7E3E38-807A
3 Faults Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Reset counter: 13
Mileage: 85562 km
Time Indication: 0
Date: 2015.11.30
Time: 12:00:06
01705 - Selection Switch for Mirror-Adjust (E48)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 12
Reset counter: 22
Mileage: 119757 km
Time Indication: 0
Date: 2007.09.01
Time: 01:14:32
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 19
Mileage: 119912 km
Time Indication: 0
Date: 2007.09.02
Time: 21:05:24
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H07 0050
Revision: 0050 --- Serial number: 01096096590000
Coding: 7350521
Shop #: WSC 19400 993 64770
VCID: 336579FA52775ADE5C-8066
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
5 Faults Found:
01701 - Dimmer for Interior Lighting
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Reset counter: 250
Mileage: 110785 km
Time Indication: 0
Date: 2017.11.06
Time: 13:33:15
02071 - Local Databus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 251
Mileage: 119538 km
Time Indication: 0
Date: 2007.08.25
Time: 16:37:02
01565 - Luggage Compartment Light (W3)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 56
Reset counter: 18
Mileage: 113204 km
Time Indication: 0
Date: 2018.01.26
Time: 15:13:36
02956 - Lamp in Trunk/Hatch Lid; Left
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 64
Reset counter: 238
Mileage: 119757 km
Time Indication: 0
Freeze Frame:
Bin. Bits: 000 001
02957 - Lamp in Trunk/Hatch Lid; Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 238
Mileage: 119894 km
Time Indication: 0
Date: 2007.09.02
Time: 19:42:30
Freeze Frame:
Bin. Bits: 000 001
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000054759
Coding: 0000012
VCID: 285F9E969BB12906F9-807C
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000038556
Coding: 0011101
VCID: 5EB3F84E8975A7B6C3-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00-00000
Coding: 0002763
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 13
Mileage: 85562 km
Time Indication: 0
Date: 2015.11.30
Time: 12:00:06
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0030
Revision: 00000001 Serial number:
Coding: 0000021
VCID: 69D9DB92403BD00E26-803C
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Mileage: 109605 km
Time Indication: 0
Date: 2017.10.15
Time: 07:22:26
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388B$087672619
Coding: 0000002
Shop #: WSC 19400 993 56090
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 A HW: 4L0 915 181
Component: J0644 BEM H12 0690
Revision: -------- Serial number: 00000000005639
VCID: 254197A2ECA3346EC2-8070
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2802032030
Coding: 344630393135313035442056413032383032303332303330
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 50
Reset counter: 255
Mileage: 68692 km
Time Indication: 0
Date: 2014.10.07
Time: 17:01:00
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0150
Coding: 0002058
VCID: 316973F2A86B68CE2E-8064
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J814149
Coding: 1021201
VCID: 24478AA6E799CD66D5-8070
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 C
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD7A2864FC9C5265D-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD07.02.08--H25001001C0157ÿ
Subsystem 4 - Serial number: 1C0157ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003468475-----
Coding: 0000001
VCID: 65C1D7A2AC23F46E02-8030
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0150
Coding: 0002058
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 K HW: 4F0 919 283 K
Component: Parkhilfe 8-Kan H12 0100
Revision: 00H12000 Serial number: 69830802600762
Coding: 0221046
VCID: 2C5762868F4905261D-8078
3 Faults Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 23
Mileage: 117180 km
Time Indication: 0
Date: 2018.04.20
Time: 12:08:55
01629 - Sensor for Parking-Aid; Front Left (G255)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 4
Reset counter: 83
Mileage: 117180 km
Time Indication: 0
Date: 2018.04.20
Time: 12:24:40
Freeze Frame:
Fault Priority: 3
Fault Frequency: 29
Reset counter: 238
Mileage: 119263 km
Time Indication: 0
Date: 2007.08.15
Time: 14:59:55
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005080126
Coding: 0010950
VCID: 2A5B649E85BD1B16EF-807E
End-------------------------(Elapsed Time: 03:04)--------------------------
Ross-Tech: Home
Coding: 0010779
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 120004 km
Time Indication: 0
Date: 2007.09.04
Time: 15:30:19
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 12.08 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 120004 km
Time Indication: 0
Date: 2007.09.04
Time: 15:30:19
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 12.08 V
Duty Cycle: 88.8 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Coding: 0000504
Revision: 00H30001
Coding: 0099473
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 119930 km
Time Indication: 0
Date: 2007.09.04
Time: 03:33:25
Freeze Frame:
Count: 64
Count: 65
Count: 128
Count: 39936
Coding: 0000131
Coding: 0002004
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 40
Time Indication: 15
Coding: 0131158
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 238
Mileage: 105273 km
Time Indication: 0
Date: 2017.07.08
Time: 12:36:56
Freeze Frame:
Temperature: 35.0°C
Coding: 0113101
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
5 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 116576 km
Time Indication: 0
Date: 2018.04.01
Time: 07:42:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 117192 km
Time Indication: 0
Date: 2018.04.27
Time: 18:04:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 238
Mileage: 119968 km
Time Indication: 0
Date: 2007.09.04
Time: 08:19:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 238
Mileage: 116576 km
Time Indication: 0
Date: 2018.04.01
Time: 07:55:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Mileage: 116620 km
Time Indication: 0
Date: 2018.04.02
Time: 16:09:00
Coding: 0014129
1 Fault Found:
Coding: 0012142
Coding: 3649158
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 18
Mileage: 119913 km
Time Indication: 0
Date: 2007.09.02
Time: 23:08:28
Coding: 0000001
Revision: 00000000
Coding: 010000
Coding: 0000006
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 80
Reset counter: 255
Mileage: 91642 km
Time Indication: 0
Date: 2014.05.26
Time: 14:06:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 103084 km
Time Indication: 0
Date: 2017.05.21
Time: 21:38:26
Freeze Frame:
ON
Coding: 0082946
Coding: 0000001
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 86580 km
Time Indication: 0
Date: 2016.03.11
Time: 14:42:19
Revision: 00-00000
Coding: 0002763
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 13
Mileage: 85562 km
Time Indication: 0
Date: 2015.11.30
Time: 12:00:06
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 22
Mileage: 119757 km
Time Indication: 0
Date: 2007.09.01
Time: 01:14:32
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 19
Mileage: 119912 km
Time Indication: 0
Date: 2007.09.02
Time: 21:05:24
Coding: 7350521
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 250
Mileage: 110785 km
Time Indication: 0
Date: 2017.11.06
Time: 13:33:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 251
Mileage: 119538 km
Time Indication: 0
Date: 2007.08.25
Time: 16:37:02
Freeze Frame:
Fault Priority: 3
Fault Frequency: 56
Reset counter: 18
Mileage: 113204 km
Time Indication: 0
Date: 2018.01.26
Time: 15:13:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 64
Reset counter: 238
Mileage: 119757 km
Time Indication: 0
Freeze Frame:
Bin. Bits: 000 001
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 238
Mileage: 119894 km
Time Indication: 0
Date: 2007.09.02
Time: 19:42:30
Freeze Frame:
Bin. Bits: 000 001
Coding: 0000012
Coding: 0011101
Revision: 00-00000
Coding: 0002763
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 13
Mileage: 85562 km
Time Indication: 0
Date: 2015.11.30
Time: 12:00:06
Coding: 0000021
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Mileage: 109605 km
Time Indication: 0
Date: 2017.10.15
Time: 07:22:26
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 50
Reset counter: 255
Mileage: 68692 km
Time Indication: 0
Date: 2014.10.07
Time: 17:01:00
Coding: 0002058
Coding: 1021201
Coding: 0000001
Coding: 0002058
Coding: 0221046
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 23
Mileage: 117180 km
Time Indication: 0
Date: 2018.04.20
Time: 12:08:55
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 83
Mileage: 117180 km
Time Indication: 0
Date: 2018.04.20
Time: 12:24:40
Freeze Frame:
Fault Priority: 3
Fault Frequency: 29
Reset counter: 238
Mileage: 119263 km
Time Indication: 0
Date: 2007.08.15
Time: 14:59:55
Coding: 0010950
schalliol
12
02-24-2011 10:32 PM
amiro
10-20-2004 11:06 AM
m4rcus?
Florida Discussion
10
01-08-2004 10:31 AM
OneEighth
03-25-2003 10:58 AM
Dogger
03-12-2002 06:43 AM
