Plug-N-Play upgrade
Plug-N-Play upgrade
I recently upgraded my drivers window switch because worn areas on the original necessitated an R&R so I thought I might as well upgrade; then I decided to do the others in order to have them match
The driver's switch needed a couple mm of plastic removed from the underside of the door handle switch housing, but the single switches fit without any modification. The part number is 4F0 959 855 B. Looks better than just 100% black rubber covered, and wont ever develop the worn-to-white-issue.
awdinut
07-04-2018 01:06 PM
