Surprise ,Surprise!! Just picked up a 05 W12 for $3,000
I got lucky guys!!
Was looking for a a8 non running so I can use for parts.
The Seller sent me pics saying its running . tags are still current.
Interior is **** , has check engine for lean codes and it “had”suspension leak. Had an extra air strut laying around , popped it in ,stopped leak and I’ve driven it now about 100 miles. Had to add green menu on Mmi to add suspension and battery level, reverse camera is next .
it has rear entertainment system, electric side sunshades , two cool features I didn’t think I’d ever get . I could not find the options codes label in the trunk. I can’t narrow down the color .It looks purple at times and it looks Greyish-blue at other times .
So I’m getting lean , mixture codes
obviously air/ fuel problems.
Is there any tips or pointers on troubleshooting ? I have VCDS so measuring values could help but I’m not sure which ones and what to watch for exactly , trouble shooting air/fuel for me is alittle tough. I was going to begin with checking for vacuum leaks. Any help is appreciated!! Thanks guys!!
AudiWorld Wiseguy
W12’s are notorious for vacuum leaks. You can bet the hard plastic vacuum lines, particularly those routed round the back of the engine are the culprit. Cracked/snapped from years of being baked. Easy fix in the grand scheme of things.
Cool thanks Dave ! My previous experience with same lean codes on a Porsche Cheyenne turbo were different, the Cayenne never gave me any hesitation at heavy throttle but it affected my idle.
With the W12, idle is perfect and all operation is great until you apply heavy load , than I get hesistation ,and sputtering . At moderate/low throttle its smooth and excellent.
With the W12, idle is perfect and all operation is great until you apply heavy load , than I get hesitation ,and sputtering . At moderate/low throttle its smooth and excellent.
The color might be Daytona Gray. In 05, brilliant black was the only available black.
Since it is a fuel trim on both banks,
I would test the fuel pumps. I cannot speak to the W12 as there were only ever 14 imported here, but with the V8, the main fuel pump gets weak and causes the same codes and issues.
You can force the secondary fuel pump to work by jumping the relay for it over the battery. Usually this pump is fine as it only works about 30% of the time. If the car runs fine after you jump this pump, then replace the main fuel pump will typically sort the lean codes.
Mike
Mike
I agree with Dave on vacuum leaks. You could be getting lean misfires or further issues but need to the lean codes and retest. Congrats on finding a W12. My 05 was great to me before I totaled her.
Looks purple , looks grey, looks black , looks blue lol I dunno, but I have 2 black phantom pearls(08’ S8 & 09’ A8 ) and this is not black lol I’ll get better pics when I can, is there a way to verify paint using vin?
The w12 was not something I expected to get into so I’m reading up on the D3 tech dump and on the forums,as much as I can to see all any possible vacuum leaks.
Mike
Mike
i did this on the Cayenne as well to rule out bad pump.
just have to find which relay/ relays correct?
It’s hard to see from my pics ,It looks black but it’s not. Here’s a few pics the seller sent me
Looks purple , looks grey, looks black , looks blue lol I dunno, but I have 2 black phantom pearls(08’ S8 & 09’ A8 ) and this is not black lol I’ll get better pics when I can, is there a way to verify paint using vin?.
Am I freakin blind or wth???
Thanks to AudiWorld forums, I was able to read up on some older posts, and someone suggested checking the intake boot for an extra hose that is attached. I also found a few pdf manuals of the W12 design ,looked it over a bit to get an idea of all the possible leaks. damn!, there is a lot, hoses everywhere ! Lol
anyway, going to plug this sucker back in , clear codes and go for another test drive! Wish me luck!
thank guys for all the help and suggestions !!! They will come in handy! something so simple like this can be overlooked .I’m ashamed I didn’t see it considering I spent a good amount of time in there ,cutting/replacing drivers latch after cable disconnected, the first night I got it!! 🤦♂️
but that’s for a seperate post ,with pictures. Btw I found options code in manual , it’s oyster grey, you were right, beautiful color
The following 3 users liked this post by Christian A:
