Think I need to replace ignition switch- Help
Hello, I have a D3 and two days ago I was driving and got a message on the screen with a picture of a key and it said ignition switch. When I got to my destination my car would not shut off and I could not get the key out. After playing around with it for about 5 min I was able to get the key out. For the past 2 days the error message has not come back on and the car shuts off fine but now it doesn't want to start. It takes 3 to 5 mins of working the key and praying for the car to start. As luck would have it I am in the middle of a move and my VagCom is in a box somewhere in a storage unit. My gut tells me that the switch needs to be replaced. What do you think? If so, I have 2 questions: 1. Does replacing the switch require and programming or can I just swap it out? 2. Are any special tools needed? Being that it is part of the dash and not the steering column I am guessing it is a fairly straight forward job.
This is the message that I got.
Well tonight it wouldn't start at all. I tried for about 15 min and then just got a ride home from work. One thing that appears to be new is that the remote no longer works to lock or unlock the door. I think it was working yesterday but I am not 100%. Also the instrument panel lights do not come on. I ordered a new switch and it will be here Sat. To be clear, when I say it won't start I mean that it is not even trying to start. Does not turn over at all. I don't believe this to be a battery issue but I will confirm that. Right now my best bet is that it is the switch. Has anyone done this job before? Any special tools or programming?
Are you sure it said "ignition switch", as I have never seen nor heard of that when I had my 04, nor in my 05 W12, but I have seen the "Key not in vehicle" warning, where did you get the picture you posted referencing "ignition switch" ?
What Louis said,
check the keyfob battery, also as Louis' link points to, do you have any wetness on or below your carpets, your KESSY/IMMO module is under the carpet on the drivers front side.
The Keyfob Battery...
Hate to say it, but this is a tow to the dealer situation.
This is From The Manual
A Malfunction in the ignition lock must be repaired immediately.
If the (Symbol Above) in the display blinks, there is a malfunction in the electronic ignition lock. An additional driver message can also be displayed by pressing the CHECK button:
Ignition lock defective. Contact workshop!
- Do NOT turn the engine off.
- Drive immediately to an authorized Audi dealer to have the malfunction corrected.
If there is a malfunction in the electronic ignition lock, the ignition cannot be turned off. Drive immediately to an authorized Audi dealer to have the cause of the malfunction corrected.
