Tire pressures, front vs back and levels. door says I think 36/38 back/front. Do you run different
pressures front to back? And what pressures do you run? My Pressure check on MMI reads about 43.6 for all 4 tires (cold), yet the door recommendation is much lower. I have not touched the air since I bought the car in October (my bad). I have stock 19" sport wheels on stock 2008 All weathers (Pirellis).
Finally, I screwed around with the MMI pressure check and deleted all the readouts by clicking on "Change Wheels". What do I do to get the readings back?
I run 38-39psi (cold) on all 4 tires. I find the higher psi level acts, to some degree, as...
...a safeguard to protect against NYC pothole damage. The new '08 suspension dampening negates the higher psi harshness that I experienced in my previous '06 A8.
You might try the Initialize Wheels setting. This may take several minutes before the tire pressures are displayed.
tubi
A4 (B7 Platform) Discussion
04-18-2009 06:32 AM
