TPMS Module Part number
I'm a relatively new 2006 S8 owner although I've owned various Audis for the last 15 years or so.
My new (to me) car has a few gremlins - one of which is the TPMS. It wont switch on via the MMI, and vcds cant communicate with the module. I've lifted the rear bench to make sure it is plugged in which it is.
The VCDS log is:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 156
Mileage: 121993 km
Time Indication: 0
Date: 2015.01.16
Time: 10:19:41
My conclusion is the module is probably dead and needs replacing. I've looked on ebay and there are plenty available. The problem is that whilst the Part number matches (4F0 907 273A), the "to be used in conjunction" label is different.
The currently installed one says use in conjunction with TX RDKS/RE, TSS/RE3, TSS/RE3b, TSS/RE4b, TSS/RE3L. The ones on ebay tend to just say use in conjunction with TX TSS/RE4T or TSS/RE3t.
My question is will these modules still work?
Thanks in advance!
The VCDS log is:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 156
Mileage: 121993 km
Time Indication: 0
Date: 2015.01.16
Time: 10:19:41
Thanks in advance!
Where would I check in vcds to see if it is turned off somewhere else (bearing in mind I can't communicate with the tpms module).
I have also tried the battery trick already when I picked the car up with no difference.
Thanks.
My thoughts are that it more than likely is identical as the part number matches and I've yet to find any parts from Audi that don't follow that rule.
I'll be giving it chance as I can get one shipped from Germany for £45 to try and then I've just got to get new sensors no doubt.
Thanks again.
Swapped it over and the TPMS still wont stay switched on through the MMI.
I've checked that module 65 is switched on under CAN gateway using VCDS and it made no difference (even tried un-ticking it to see if anything happened and it didn't)
Has anyone got any other ideas?
I am getting the following error under CAN gateway (in addition to the TPMS error) :
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 156
Mileage: 121993 km
Time Indication: 0
Date: 2015.01.16
Time: 10:21:26
I'm guessing this is caused by the Dension that is fitted??
Thanks,
See my prior post reply here, and third picture toward bottom: Vehicle Sub-Menu in Hidden Menu - AudiWorld Forums
