Understanding how the Mmi system works
Old Oct 30, 2013 | 03:44 PM
Smitty5534's Avatar
Default Understanding how the Mmi system works
Ok I have a couple questions that will greatly help me if someone knows the answer. My mmi system is completely dead no power at all and nothing lights up. That being said my two questions are this:
How does the most system work I know it connects each component but if one component is bad will it cut the signal or does it cut the power to the next component to?
Also it came up from vagcom that my control board has error with the power and the optical. I took the plug out to the unit behind the dash and test the plug and two pins are getting power. Will the most loop still not let it power up or would it still at Least send power to the button controls if it was good?
Please help me understand how this system works or point me to a website that explains it well. I'm smart lol I just need it explained lol thank you
Old Oct 30, 2013 | 04:36 PM
MP4.2+6.0's Avatar
Tech Guru
Default Try this: the original SSP
This was Audi's service training on MMI back when the car was released--their nomenclature being "Self-Study Program":
http://www.google.com/url?sa=t&rct=j...55617003,d.eW0
Hopefully the link works. If it goes dead, search on "Audi" "Self-Study Program" "993303" df It's currently a pdf at 1stcallhosting.com. These move around over time from looking for them off and on.
Old Oct 30, 2013 | 07:03 PM
Smitty5534's Avatar
Thank u that is great info!! I still don't understand the most buss system and if it supplies power or just communucation between the devices...
Old Oct 30, 2013 | 09:26 PM
ltooz_a6_a8_q7's Avatar
Default MOST bus system is just data travels through optical cables
instead of electrical wires for faster data transfer. It doesn't have power to turn (switch) on/off anything except tells something to turn something else off/on. The reason it's different from other data cables, data can travel in parallel with normal wires, this MOST system, it serially (daisy chains) travels from one device to the next and comes back to the source, 1 chain link breaks, the system halts.
It's not hard to isolate the culprit device, just remove the device and close the loop.
Cheers,
Louis
Old Nov 4, 2013 | 04:13 PM
Smitty5534's Avatar
I got a bypass ring from audi and removed the most buss plug to the radio,navigation,amp,media player, and still isn't working. I'm pretty sure it's the control board. I'm gonna order one on eBay. I read it's a 50/50 chance it won't go into protection mode? If it does the only place that can fix it is the dealership? How much does this cost? Thanks guy
Old Nov 4, 2013 | 04:21 PM
mishar's Avatar
Tech Guru
It would help if you post that error report here. MY of your car too. You are not mentioning Bluetooth. Do you have it?
If it is really Gateway I have one working perfectly and cheep.
Old Nov 4, 2013 | 05:25 PM
Smitty5534's Avatar
Mishar thanks for replying. Heres the report let me know what you think thanks
Control Module Part Number: 4E0 910 468 A
Component and/or Version: Gateway H06 0020
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK ERROR
07-Control Head ERROR ERROR
0E-Media Player 1 OK ERROR
47-Sound System OK OK
56-Radio OK ERROR
37-Navigation OK ERROR
Heres the Full scan:
************************************************** ******Sunday,27,October,2013,17:04:42:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Sunday,27,October,2013,16:48:10:32264
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E74N003196 Mileage: 167180km/103880miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0050
Revision: 00000000 Serial number: AUX3Z0C4514519
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F47FDA5CEA6FD1
7 Faults Found:
18348 - Powertrain Databus
P1940 - 008 - Missing Message from Control Module for Battery Monitoring
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
18282 - Valve for Torque Support Mount
P1874 - 001 - Short to Plus
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low
17766 - Cylinder 2 Ignition Circuit
P1358 - 004 - Open Circuit
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0031986
Coding: 0000002
VCID: 244DF249E7C0DE9
2 Faults Found:
16944 - System Voltage
P0560 - 000 - Malfunction - Intermittent
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 20.0°C
T.B. Angle: 0.0°
Voltage: 12.24 V
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 20.0°C
T.B. Angle: 0.0°
Voltage: 12.24 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2143FB5DF8D2CB1
2 Faults Found:
18265 - Load Signal
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H02 0120
Revision: 01203602 Serial number: AUX3Z0C4514519
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: D8B516B96B08CA9
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 77
Mileage: 167184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:29:30
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
VCID: 234FF155E2CED91
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 78
Mileage: 160028 km
Time Indication: 0
Date: 2003.03.16
Time: 05:41:05
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 015 0240
Revision: 00000017 Serial number: 00000000017152
Coding: 0037313
VCID: DAB10CB11504D89
Part No: 4E0 910 772
Component: Sitzluefter FS H05 010
Component: Sitzluefter BFS H05 010
5 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 76
Mileage: 138489 km
Time Indication: 0
Date: 2003.03.18
Time: 00:44:12
Freeze Frame:
ON
Bin. Bits: 00001111
01869 - Left Rear Cold / Warm Air Outlet Motor Position Sensor (G351)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 154
Reset counter: 116
Mileage: 163180 km
Time Indication: 0
Date: 2003.03.01
Time: 21:39:12
Freeze Frame:
Voltage: 13.20 V
(no units): 121.0
(no units): 255.0
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 233
Mileage: 138172 km
Time Indication: 0
Date: 2003.02.27
Time: 02:40:07
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 116
Mileage: 138736 km
Time Indication: 0
Date: 2003.03.19
Time: 07:12:38
Freeze Frame:
Voltage: 13.50 V
(no units): 173.0
(no units): 255.0
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 95
Mileage: 164652 km
Time Indication: 0
Date: 2003.03.19
Time: 05:53:24
Freeze Frame:
Voltage: 13.20 V
(no units): 120.0
(no units): 254.0
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111113
VCID: 2A511C7185E4089
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02313
4 Faults Found:
00908 - Control Module for Wiper Motor
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 161362 km
Time Indication: 0
Date: 2003.03.11
Time: 07:27:54
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 113
Mileage: 153977 km
Time Indication: 0
Date: 2012.08.15
Time: 11:32:49
00818 - Sensor for Evaporator Outlet Temperature (G263)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 78
Mileage: 167186 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:05
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 166349 km
Time Indication: 0
Date: 2003.03.01
Time: 05:45:23
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 A
Component: Airbag 8.4E+ H08 0820
Coding: 0530707
3 Faults Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - MIL ON
01742 - Igniter for Knee Airbag; Drivers Side (N295)
01220 - Rear Side Airbag Igniter; Passenger Side (N202)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H09 0030
Coding: 0012241
VCID: E5CB2F4D2C7A671
Component: Lenkradmodul H02 0050
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 77
Mileage: 167186 km
Time Indication: 0
Date: 2003.02.27
Time: 00:29:34
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
Date: 2127.15.31
Time: 31:63:34
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H42 0070
Revision: D08 Serial number: AUDID3C4001513
Coding: 0000223
Shop #: WSC 03164 444 57801
VCID: DCBD0AA91F30269
1 Fault Found:
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 251
Reset counter: 114
Mileage: 154017 km
Time Indication: 0
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H06 0020
Revision: 06 Serial number: 50003421052901
Coding: FCFE7BDD1B2304
Shop #: WSC 09807 444 54400
VCID: 2649E84191FC2C9
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 78
Mileage: 167186 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:01
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 77
Mileage: 167184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:29:30
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 08256 444 00182
VCID: 254BEF4DECFA271
2 Faults Found:
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 78
Mileage: 167186 km
Time Indication: 0
Date: 2003.02.27
Time: 00:29:30
00776 - Level Control System Sensor; Left Front (G78)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 11101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 78
Mileage: 0 km
Time Indication: 0
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H06 0060
Coding: 4071650
3 Faults Found:
01877 - Belt Height Adjustment Button (E333); Down
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 78
Mileage: 155876 km
Time Indication: 0
Date: 2003.02.27
Time: 00:03:21
Freeze Frame:
Fault Priority: 6
Fault Frequency: 62
Reset counter: 78
Mileage: 155892 km
Time Indication: 0
Date: 2003.02.27
Time: 01:36:22
01876 - Belt Height Adjustment Button (E333); Up
006 - Short to Plus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 78
Mileage: 155876 km
Time Indication: 0
Date: 2003.02.27
Time: 00:03:21
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics Labels: None
Part No HW: 4E0 907 135 A
Serial number: 00000412500150
VCID: 55AB9F8DBC1A771
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 13
Reset counter: 78
Mileage: 167184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM004 0080
Coding: 0028196
VCID: DEB900A1092C349
No fault code found.
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040802220058
Coding: 0065086
Shop #: WSC 03164 444 83924
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H02 0020
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 78
Mileage: 138154 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:03
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 77
Mileage: 141037 km
Time Indication: 0
Date: 2012.03.17
Time: 17:09:08
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0060
Revision: Serial number: 00000000015402
Coding: 0010111
VCID: DDBB07AD042A2F1
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 78
Mileage: 167184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:29:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM004 0080
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 74
Mileage: 167184 km
Time Indication: 0
Date: 2003.02.27
Time: 00:08:51
Freeze Frame:
Voltage: 12.94 V
Count: 61
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Coding: 0000001
VCID: E2C134513D54109
1 Fault Found:
01310 - Level Control System Control Module (J197)
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 78
Mileage: 167192 km
Time Indication: 0
Date: 2003.02.27
Time: 00:29:35
Address 56: Radio
Cannot be reached
Address 61: Battery Regul.
Cannot be reached
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0080
Coding: 0028196
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: DFC73DA50E263D1
3 Faults Found:
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 3
Fault Frequency: 8
Reset counter: 115
Mileage: 164393 km
Time Indication: 0
Date: 2003.03.03
Time: 22:06:22
Freeze Frame:
Speed: 255.0 km/h
Voltage: 8.90 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 253
Reset counter: 78
Mileage: 165526 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:59
Freeze Frame:
Speed: 0.0 km/h
Temperature: 24.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 76
Mileage: 127790 km
Time Indication: 0
Date: 2009.11.05
Time: 21:01:05
Freeze Frame:
Speed: 0.0 km/h
Temperature: 1.0°C
Error Code: 480
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0080
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3002273
Coding: 0000005
Shop #: WSC 03164 444 53905
VCID: E0C53E593058029
4 Faults Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001208
VCID: E0C53E593358029
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 90
Mileage: 166178 km
Time Indication: 0
Date: 2003.03.09
Time: 01:40:07
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 90
Mileage: 164962 km
Time Indication: 0
Date: 2003.03.05
Time: 11:45:53
End ---------------------------------------------------------------------
Old Nov 4, 2013 | 06:12 PM
mishar's Avatar
Tech Guru
Interesting data:
Mileage: 1048575 km
Time Indication: 0
Date: 2127.15.31
Time: 31:63:34
Most of errors are from the beginning of 2003, I believe before your car was made.
I would suggest that you clear all those codes and perform a new scan.
You have Telematics, so it would be 2004 or early 2005 car. No Bluetooth. One less to look at.
Old Nov 4, 2013 | 07:07 PM
Smitty5534's Avatar
I did run a new scan and most of the faults were gone. All the cannot be reached codes were still present. Do you think its a good chance its the 07 control board and if so can you pm me how much you could sell me the one you have? thanks buddy Jeremy
Old Nov 4, 2013 | 07:55 PM
mishar's Avatar
Tech Guru
It could be Control Head Module 07. Unfortunately I don't have it anymore. I sold it for $200. I have Gateway Module but I believe you don't need that one. If you buy Control Head Module without F-bas (coaxial green plug you need if you want to install backup camera) it shouldn't be much more than $200. May be even less. There are quite a few of them around and they don't brake usually. PayPal will protect you if the unit is faulty and the seller not really honest.
Your CD changer (Media Player) can't be reached too. You may use the loop there if it is also broken and replace it later, may be with AMI.
