urgent help please Dead battery cannot access trunk
Lessons learned: If the key is locked in the ignition on the left side closest to the steering wheel. Remove the cover get a paper clip turn the key to the left. Place the paper clip inside the hole. "Here's the catch" the paper clip goes inside the hole there's another hole within the hole. Place it inside and push toward the key and pull the key out.
In the event the master key doesn't open the trunk use a long broom stick and use the emergency latch on the right side of the back of the trunk.
Hopefully this will help someone in the event they have a dead battery. After all the hassle it really wasnt thst hard. Take care and God bless.
Now the $64 question is: What caused the battery to go dead?
If it is the original it is well past the need for replacing.
Keep an eye on the battery level meter in MMI.
While it's not terribly accurate, anything less than 100% indicates an issue.
Broom stick would be recommended if you didn't exclude it by "trunk full of bags" in your first post.
