V71 and J520 errors
Old Apr 15, 2013 | 05:05 AM
Vicl's Avatar
Default V71 and J520 errors
Good morning, Gentlemen!
First I'd like to apologize for asking stupid questions... But first time I scanned the car and first time I see errors in my life. When some errors are not concern (I think) the other makes me worry (08-Auto HVAC and 38-Roof Electronics)
Have someone seen such errors and what would be the process to fix them?
Thanks a lot
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G5725730
Coding: 0410624
Shop #: WSC 02313 758 00200
VCID: D8BFD1616BE319D8B9C
Part No: 4E0 905 852 E
Component: ELV 1940
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 5
Reset counter: 117
Mileage: 60336 km
Time Indication: 0
Date: 2013.01.11
Time: 19:23:20
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
VCID: 24473591E72B0D38654
1 Fault Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 123
Mileage: 62724 km
Time Indication: 0
Date: 2013.03.31
Time: 18:06:17
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000123768
Coding: 0037185
VCID: 1C370D71DF5B35F8DD4
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 99
Mileage: 48957 km
Time Indication: 0
Date: 2011.06.09
Time: 10:19:20
Freeze Frame:
Voltage: 13.70 V
Temperature: 25.0°C
(no units): 195.0
(no units): 193.0
Temperature: 25.0°C
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000712400045
Coding: 0003477
VCID: 1D310075C4413CF02AA
1 Fault Found:
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 117
Mileage: 61548 km
Time Indication: 0
Date: 2013.02.16
Time: 09:30:00
Old Apr 15, 2013 | 07:39 AM
mishar's Avatar
Tech Guru
You should save those codes to a log file and clear them. Than you will see if any of them comes back. Most likely none of them.
Old Apr 15, 2013 | 07:45 AM
Vicl's Avatar
Thanks! I saved it to the log, I'll clean those errors next week then when I'll do rear brakes
Thanks a lot Misha!
Old Apr 15, 2013 | 07:54 AM
MP4.2+6.0's Avatar
Tech Guru
Default Note the date and miles (km) on the HVAC one
The HVAC one is quite stale by mileage and date. Sunroof is newer but may just be more random noise. The obvious problem ones are when you clear it and it comes right back onto your screen, immediately or after the next drive or two; even the sunroof one is a few months old now.
Old Apr 15, 2013 | 08:54 AM
mishar's Avatar
Tech Guru
There I have a question: is that date when that fault was first or last time detected?
Old Apr 15, 2013 | 09:59 AM
Vicl's Avatar
That is very good question
Old Apr 15, 2013 | 10:16 AM
jakematic's Avatar
Last detection time.
Fault frequency indicates how many times the DTC occurred.
http://www.ross-tech.com/vcds/tour/dtc_screen.html
Old Apr 15, 2013 | 11:26 AM
mishar's Avatar
Tech Guru
Thanks Jake.
Old Apr 16, 2013 | 04:03 AM
Vicl's Avatar
Yesterday, before cleaning the errors I opened the AC Cabin filter and found true mechanical failure. The filter was deformed and was interfering with flap movement. The car could not close it in full and rather left it always open. After removing the filter and starting the car it fully closed the flap and reopened it in full. I had new filter so I replace it and erase the errors.
Now, few observations:
I read description provided by Jake http://www.ross-tech.com/vcds/tour/dtc_screen.html , but it does not say anything about Date on the error. But instead I can confirm the data stamp is actually when it First Occurred. The reason why I'm 100% sure is following. First of all it is logical (you better know when it failed first time rather than have it each time re-set). Second when I looked at my records the failure occurred same day when the filter was replaced (Date: 2011.06.09). It definitely proves the date represent the first occurred event.
Second interesting observation:
For some reasons VAGCOM shows lover mileage then actually car shows on the dash. And it is consistent about 2K less (I have odometer record when the filter was replaced as well... It is about 2K difference between error log. Also when I start VAGCOM it is reading current mileage and it is 2K KM less then I see on the dash as well). What does it mean? Do you think the A8 is trying to hide her age like real woman?
Old Apr 16, 2013 | 05:51 AM
jakematic's Avatar
I stand corrected.
That does make more sense.
On the mileage I believe the computer estimates it based on wheel pulses like Nav uses.
It is designed to prevent roll backs. http://www.ross-tech.com/vcds/tour/EDC-15-Mileage.html
