Warm the engine
Old Oct 18, 2010 | 09:14 PM
Flats's Avatar
Default Warm the engine
07 A8, how do you leave car running and lock the doors with the keyless start? Thanks in advance...Flats
Old Oct 18, 2010 | 10:23 PM
Brozee's Avatar
Pretty sure you can't lock the car if you and your keys are outside of the car when it is running. The car will signal that the keys are not in the car anymore as well. Designed as a safety feature to not lock your keys in the car etc I believe I am correct on this post.
Old Oct 18, 2010 | 11:14 PM
ModestW12's Avatar
Try manually locking the door after it's running using the physical key hole in the door handle (visible when you lift up on it).
Never tried it with the 2007 W12 but I used the key hole once when I had the 2004 A8L.
The G Man
Audi A5 / S5 / RS5 (B9)
Nov 30, 2018 07:42 AM
nhs156
Q7 MK 1 Discussion
Sep 21, 2016 08:18 PM
schnelldiesel
Q5/SQ5 MKI (8R) Discussion
Jan 4, 2014 04:12 PM
verukacat
Mar 6, 2010 02:13 PM
Levent
Jan 25, 2001 11:00 PM
