'15 D4 4.0 ChipWerke Experiences/Results??
#11
Thanks cleex024. Good to know. How about the difference in sound when you added Stage 2? Sounds like you have the downpipes but are running in stock mode to run 11.3 with the Chipwerke? I agree that I would expect to hit 10.9 with Stage 2. Do you recall the DA and temp on your 11.15 run? ET? Hell, post the slip if you have it! Ha.
Speaking of which, I expected the redline to jump from 6500 to 7000 with Stage 1. Was curious if there was any discussion around that - I figured with lighter internal components, the S8/RS7 could handle it.
Also I wouldn't worry too much about the red line going from 6500 / 7000 as it seems there are some power loss up top.... Plus I think the red line is 6800.
#12
I'm at Deer sea level and the temps were about a hundred degrees Fahrenheit... SoSo there was probably some some heat soak in there
Pre95
NorCal Discussion
02-17-2009 07:43 PM
albe1
Audi allroad
06-22-2007 07:16 AM
LeadingEdge
9
10-13-2003 03:24 PM
