35k service
Plugs are ~$150, coilpacks are ~$200, cabin filter was $35, oil and filter will cost you $75 if you get the 5 quart jugs from wally world. These are parts prices.
Plugs will probably take you a few hours at an easy pace just because of all the crap you have to disconnect. If you do it yourself be CAREFUL with any plastic clips as they break very easily.
Also, depending on how fast car accumulated miles, the 2 year brake fluid flush that is solely time dependent typically occurs at 25K or 35K. Some just standardize, probably at 25K. Should show on maintenance paperwork, at least the brake fluid. Can get overlooked by dealer because it goes by time, so good to check paperwork. Up to half the time, my dealer has probably missed it across 5 different Audi's that have had AudiCare or its equivalent.
CPO does not include service BTW, so I expect what is probably the case is prior owner bought AudiCare for the first 50K miles. If so, that transfers w/ the car.
Driving scenario is 100% irrelevant. What is relevant is atmospheric humidity. Your car could be parked for 6 years w/ same result. Brake fluid is hydroscopic, meaning it collects water. If you live in a humid area, not good. If you live in a dry area, in theory you could skate longer. Risk is brakes not there when you really need them though. Fluid can start to show enough water accumulation to affect peak performance in as little as a year. In dryer areas, probably several years. Consequence is it lowers boiling point of fluid. And when it boils--like repeatedly using your brakes and pedal starts to go soft/brakes fade--not good. They sell test strips if you want to go that way and monitor instead.
