Sponsored by:
Sponsored by:
Adaptive cruise control problem
Old 10-27-2016, 03:15 PM
dildildil's Avatar
Default Adaptive cruise control problem
bought the car with ACC, braking guard and audi lane assist not working. with the regular message " ACC AND BRAKING GUARD UNAVAILABLE" i figured it was out of alignment and probably will need calibration... so finally made an appointment at the dealer and after keeping the car for whole week they are telling me that my front left sensor is bad.
i didnt pay for new sensor and decided to pick up the car now i have no errors on my cluster and surprisingly lane assist is working perfectly however the cruise control doesn't work like if its not even installed in the car i can press any button on the stalk and nothing .... before everytime i tried to use the cruise control or even lane assist it would tell me cruise control or lane assist unavailable.
does lane assist work using the camera mounted on the windshield only or does it also uses the 2 sensors that are located in the front bumper ? becoz if lane assist uses the radar sensors aswell then i doubt the sensor is bad and its just misalignment
the sensor is about 2000 with tax and i can probably buy it cheaper online new one or alot cheaper for a used one but i will need to pay for calibration again heres the fault code i am getting when i scanned my car again, dealer says the j450 module is sending signal but not receiving it
Old 10-27-2016, 04:49 PM
Jack88's Avatar
Lane assist uses a camera, behind the mirror I believe. The OEM part is cheapest here, if that's what you end needing. Interestingly, whether it's the right or left makes a fair difference in cost. As with anything electrical, inspecting the condition of the wires and connectors is always worth doing.
Old 10-27-2016, 05:19 PM
MP4.2+6.0's Avatar
Adaptive cruise are the two outer sensors in the fog light position, at least with LED's like my S8. Likely the brake assist function too. Might be in mirror area for lane assist. Front visual camera for MMI parking and 360 display is in ring area with the rounded face. If night vision equipped, I think that is a large round flat sensor in another part of rings.
Backing up to OP, I saw this same issue on a 2015 S8 CPO I test drove locally. I went out to freeway with it--with no salesman on board --and eventually got to ACC and got that same error immediately. When I got back and started looking car over, I pushed on bumper and it seemed strangely loose. Then I saw majority of screws missing in fender area on both sides. At that point it was clear someone did a hack job on it, likely at auction yard (...it was perhaps washed through). Obviously explained the ACC error I saw too. Very disappointed that car was labeled CPO. The checklist would not have been worth the toilet paper the tech skipped while filling it out in the John with a brewski or two in hand. Needless to say, i was on my way to the one I eventually bought in the next 5 minutes.
Old 10-27-2016, 11:28 PM
dildildil's Avatar
Since they had the car for whole week they checked the ground and power and all other cables and found nothing wrong with them, the voltage reading is same for front left and right sensor i just dont want to buy the sensor and findout something else is an issue wondering if anyone else had same issue where error code was for misaligned sensor and needed to replace it or is the tech at the dealership just doesn't know what hea doing.
Also what did they do to deactivate the error message aswell as no response from the cruise control stalk ? Alot of my settings were changed like seatbelt warning and all is there anyway i can check in vcds if cruise control was deactivated?
Only other thing i can think of is if they left something unplugged
Thanks
Old 10-28-2016, 01:43 AM
Jack88's Avatar
VCDS can tell you if it's been deactivated. You just need to check the appropriate module. It's odd that your stuff is shut off entirely. Makes me want to suggest a second dealer look at it. I tend to be quick to be suspicious of dealers, though. Feel free not to take their word for it on the wiring and connectors.
regalnut86 (05-30-2020)
Old 10-28-2016, 03:02 AM
snagitseven's Avatar
The camera in front of the rear view mirror and the two radar sensors in the front bumper are used for ACC and Lane Assist.
Old 10-28-2016, 07:22 AM
dildildil's Avatar
my lane assist works perfectly ...
cruise control is not working as if its been deactivated ... no error either
i want the system to tell me acc and brake guard not available like before...
can anyone confirm if lane assist works with the front camera on the windshield only without the outer 2 sensors
its a 2011 audi a8l
thank you
Old 10-28-2016, 07:40 AM
MP4.2+6.0's Avatar
Text and illustration from the D4 intro SSP about ACC. Sensors in bumper; text explains where camera comes in.
Just know what Audi says there, other than you can find the configuration check box stuff when you go into module coding with VCDS. Someone could have played with that deeper in I suppose. Not good/right and perhaps fraud in connection w/ sale of a vehicle if that actually happened, but that's another discussion.
Attached Thumbnails Adaptive cruise control problem-screen-shot-2016-10-28-8.37.07-am.png
Old 10-28-2016, 11:06 AM
Now that I think about it, it would make sense that lane assist would be a visual detection (camera only) and the bumper sensors would not come into play. ACC would need to use both - radar and visual. I have both the camera and the sensors installed but my car does not have lane assist, only ACC.
Old 10-28-2016, 12:08 PM
dildildil's Avatar
i scanned the car today this is what i have ....
Address 13: Auto Dist. Reg Labels: 4H0-907-561.clb
Control Module Part Number: 4H0 907 561 A HW: 4H0 907 561
Component and/or Version: ACC3 H15 0160
Software Coding: 3601020201
Work Shop Code: WSC 02313 785 00200
ASAM Dataset: EV_AdaptCruisContrAU64X 001012 (AU64)
ROD: EV_AdaptCruisContrAU64X.rod
VCID: 294022D319F9DBCA68FE139-807C
5 Faults Found:
11264 - Sensor for Automatic Distance Regulation
C110B 49 [009] - Internal electronic failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 222
Mileage: 210750 km
Date: 2016.10.27
Time: 10:29:55
146688 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 210785 km
Date: 2016.10.27
Time: 16:19:00
82688 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 210785 km
Date: 2016.10.27
Time: 16:19:00
102912 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 210785 km
Date: 2016.10.27
Time: 16:19:00
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 222
Mileage: 210750 km
Date: 2016.10.27
Time: 10:29:55
Address 8B: Adaptive Cruise 2 Labels: 4H0-907-561.clb
Control Module Part Number: 4H0 907 541 A HW: 4H0 907 541
Software Coding: 3E01020201
ASAM Dataset: EV_AdaptCruisContr2AU64X 001010 (AU64)
ROD: EV_AdaptCruisContr2AU57X.rod
VCID: 274424EB0FEDEDBA7EEA651-8072
1 Fault Found:
12288 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 222
Mileage: 210804 km
Date: 2016.10.27
Time: 17:57:55
4h0 907 541a is left sensor and dealer told me this one is BAD
4h0 907 561a is right sensor according to the scan it seems as if there is a issue with right sensor or do u guys think its becoz of left sensor acting up ?
Quick Reply: Adaptive cruise control problem
