Additional tune up items?
I was contemplating tackling a few extra items on my 14 3.0 Something I used to do rather easily on my previous vechiles. This is cleaning the throttle body and MAF sensor. Have any of you guys tackled this on your Audi? It looks fairly easy to access. How about the PCV valve? Something that should be changed? I'm all about preventive maintenance.
Also, does the A8 have an smog sensor that switches to recirculate when carbon monoxide is detected? I really loved this feature on my previous Lexus vechicles but I don't see an option for this.
The PCV valve on this car is best left alone unless it fails. I'm fairly sure the one on the 3.0t is among the overly complex units Audi has liked to use, but otherwise feel free to clean stuff up. I can't tell you how easy those are to remove, but they appear simple enough to my eye. The smog sensor is a new one on me, it's not a feature I'm familiar with on any car.
Hmmm, that's too bad Audi does not have this. Really a fantastic feature to help prevent nasty fumes from entering the cabin. Just a simple sensor that was mounted on the LS right in front of the radiator and it would automatically switch to recirculate if it detected smog. You could set the sensitivity as well. Even my old 2004 LS430 had it.
I did search for pcv valve on my car and it does look way more complicated then necessary. Got to love German over engineering. Something I am getting use to. I just ordered some new tools to do some of the basics. I swear, they really don't want the average owner to do much on these cars... lol
Sort of slow to load, but here is that source document from when Audi first released the 3.0T. D4 version perhaps somewhat tweaked, but they usually only do these to train the techs when a new motor is first released: http://www.vaglinks.com/vaglinks_com...FSI_Engine.pdf
You can also change the recirc. sensitivity if you poke around in the settings you see via the MMI display under Car/AC. See pic below.
Thanks MP, as usual you are a wealth of information. I noticed this in MMI as well but not sure how well it actually works. I also get whiff when using the windshield wipers and I have yet to notice the system automatically switch because of smog. I will set the sensitivity to max and test again. The reason I mentioned this is because on the Lexus you could easily remove it and open up the sensor for cleaning as it would become full of gunk over the years and the sensitivity would be compromised. Part of the tune up process for many. By the way, I have my VCDS unit on order. Can't wait.
While at it, check wiper blades too to see if really in top shape. Dealers don't do those under AudiCare or warranty except for $. I'm finicky on those and do way before they fall apart. Giving my 2015 until about next season. Another easy web dealer part with no rush.
Funny you mention this, the first thing I did was order a cabin filter off Amazon. When I pulled out the current filter it was still in great shape. Their only $15 on Amazon. Very easy to do as you mentioned. I also replaced the engine air filter with a K&N filter.
I ran a bottle of Dura Lube fuel system cleaner when I first got the car. A few tanks later I put in a bottle of the Berryman B12 after reading good things about it with a Costco 93 octane fuel up. She is idling incredibly smooth now.
I hear you. I have never had any issue with K&N but I know some have. Usually problems can come from users over-oiling them and fouling the MAF.
This is one I purchased. I have used them in the past with good success.
