Brake Job Questions
Brake Job Questions
I'm replacing rear rotors and ceramic pads front and rear. I have the scan tool to engage/disengage EPB. I took everything apart yesterday without much problem but once I got to removing the caliper bracket I didn't have the right torx bit. It requires 12 point bit and I only have 6 points so I'm waiting for the part from amazon.
Qustion - Audi D4 A8L rear brake caliper, does the piston need to be twisted in using a winding caliper tool? If so, is it the same for front caliper pistons?
I'll try to take some pictures and create a DIY as I couldn't find too many detailed instructions out there. I've seen some but its very general and doesn't tell you what tools are needed.
Thanks for the reply. I purchased a winding caliper tool thinking most VW and Audi rear calipers have twist in pistons. Can I still use that for a caliper piston that doesn't require twist/winding retraction? or will that damage the piston?
Don't take the torx out of the . Just take the bolts off the caliper sliders as I recall. Look closer at it up above, not below where the torx bolts are, there's nothing to it.
Brandono
Audi 100 / A6 (C4 Platform)
21
12-11-2006 11:41 AM
mmart6545
06-13-2004 06:15 AM
computrtutr
9
04-17-2003 09:21 AM
