Brake Question
Brake Question
My 2011 audi a8l that has 380mm rotors in front instead of 356mm as some do,
im due for new pads n rotors for the front could i buy 356mm rotor n pad set would that work or is caliper going to be different aswell ?
the reason for doing this is the 356mm rotors are alot cheaper then 380mm which u can only get at audi.
thanks
thanks
thanks
thanks
356 is a rear size. Rears are conventional cast iron. Front are the unusual floating pin center hat type. Different calipers, different bolt up points, computer brake calculations for ABS/ESP set to brake rotor set up, etc.
im gonna buy the original one that came on the car 380mm
some a8s came with 356mm in Front i was hoping to buy those but i dont want to change calipers n all that
efudd105
07-31-2003 01:27 PM
