Sponsored by:
Sponsored by:
Could REALLY use advice on PCV valve
Old 04-18-2018, 07:33 AM
  #31
MP4.2+6.0's Avatar
Originally Posted by Psy Wagon
Small tidbit to add. The part number in the TSB lists the PCV as 079103542D
The part I got at the dealer was 079103542E
Not uncommon for part numbers to change but I wonder if they did revise the design in some way.
The part # would be a revision, so maybe a clue they are trying to improve it. They probably have a very big bin somewhere of returned warranty parts for starters.
Agreed w/ sentiments and thoughts about possible recall. Keep receipts for any out of warranty repairs. From watching situations like Audi coil packs and MAF's over the years, this feels like it may eventually end up w/ a recall and then reimbursement for any owner expenses already incurred.
Old 04-19-2018, 09:03 AM
  #32
Psy Wagon's Avatar
Oh boy. oil was indeed getting into things. My question is - are these failing on some level before you get the whistling noise?
Old 04-19-2018, 02:53 PM
  #33
BTAudi's Avatar
I received several error codes related to the intake system before any whistling which is why the dealer discovered the faulty PVC valve.
Old 04-25-2018, 06:02 AM
  #34
Psy Wagon's Avatar
Not a totally related issue but trying to post as much info for people in the future troubleshooting...
1 day after swapping the PCV the car threw the following code:
P0491 - Secondary Air Injection System Insufficient Flow Bank 1
I doubted the air pump would coincidentally go right after the PCV so poking around it seemed to be a vacuum line that wasn't re-attached properly!
Further reading: https://www.obd-codes.com/p0491
Old 04-29-2018, 11:10 AM
  #35
rmashton's Avatar
Originally Posted by BTAudi
Mine was replaced at 44k miles on a 13' S8 as well. Paid $1400 out of pocket due to my APR Tune voiding the remaining power train warranty
yes, there is about $1k of labor. the PVC valve is located under the turbos. turbo removal is necessary
Turbo removal is not necessary. My wife on vacation a few months ago experienced the oil separator/pcv failure in Phoenix on here way to Disneyland in CA. I'm a mechanic/shop owner by trade. After having my son help her pull codes and do some research, we concluded what the problem was. She rented a car, went about her way on vacation while I determined course of action. Drive the 4 hrs one way and attempt the repair on my own, load it on a trailer and pull it home or have a dealer do the job. After calling the Audi dealer service department, and hearing they were booked into the following week I decided I would attempt the repair in my parents driveway with simple hand tools bought at the harbor freight store as I didn't know what I would need. Long story short, it took about 5 hrs to do the repair. Most difficult portion was the intake on either head at the front of the car. Not much room to get those screws holding the halves together.
Old 04-29-2018, 12:28 PM
  #36
BTAudi's Avatar
wow, good to know. well done.
Old 06-25-2018, 06:27 AM
  #37
dpwS7's Avatar
Same problem here. 2015 S7 with 57,000 miles. Engine started whistling and just took in for service. I was told on the 4.0T, the valve is located underneath the engine and labor would be over $1200 with total cost of approx. $2,000 - this is crazy. I agree - There should be a recall on this as way too many issues and no way this part should fail with just over 50K miles.
Old 12-29-2018, 10:19 AM
  #38
the_duke's Avatar
Mine just failed at 86k. My CPO ran out about a month ago. Negotiating with Audi to see if they will cover it. I highly doubt they will. Seem like it won't be too difficult to do. The A8 and S8 don't require front bumper removal. I'm still driving the car while they make up their mind. With the CEL on it definitely prohibits boost. It hasn't affected fuel mileage though.
Old 12-29-2018, 12:06 PM
  #39
sushistrip's Avatar
Here is the parts list from when I did my PCV valve/Oil separator, 2013 A8 4.0T, total was about $480 all genuine Audi parts. Manual says to replace all gaskets, so that's what I did.
Description:OIL SEPARATOR.
Part Number: 079103542E
Quantity:1
Price:$292.00
Description:Air guide gasket. Intercooler gasket.
Part Number: 079129717J
Quantity:1
Price:$49.60
Part Number: 079129717K
Quantity:1
Price:$49.60
Description:Adapter seal strip.
Part Number: 079145417B
Quantity:2
Price:$19.25
Description:GASKET. Throttle valve seal strip.
Part Number: 079145818
Quantity:1
Price:$13.10
Additional info:
I reused all my hose clamps as I found a nice tool for crimping them, similar tool on ecs:
https://www.ecstuning.com/b-schwaben...UaAmhPEALw_wcB
The only other "special" tool I needed was a very long 5mm hex/allen key, about 8 inches long. Other than that, have a good set of socket extensions and universal joints.
EDIT: You'll also need a coolant refill tool. This creates a vacuum in the system (simultaneously checking for leaks =]) allowing you to perfectly fill it with coolant.
https://www.ecstuning.com/b-schwaben-parts/coolant-refill-air-purge-tool/003466sch01/
Old 12-31-2018, 06:03 PM
  #40
ttboost's Avatar
Yep, $500 in parts and about a 4 hr job...did mine at 78k miles...easy job actually...also 4 hrs to do downpipes, and 2 hours to do plugs (but plugs will go faster next time)...
Quick Reply: Could REALLY use advice on PCV valve
