Sponsored by:
Sponsored by:
Could REALLY use advice on PCV valve
Old 01-19-2019, 09:57 AM
  #51
the_duke's Avatar
In the process of doing mine now. It can be done without draining the coolant. I just clamped off the rubber hoses and put a plug in the block where the one hose bolts in. So far it's pretty easy. I have all day so just taking my time. I'll post some pictures when I'm done.
Old 02-10-2019, 01:44 PM
  #52
the_duke's Avatar
The job was pretty easy. Just takes some time. Could have probably finished in less than 4 hours but I wasn't in a hurry. No need to drain the coolant. Just clamp off a couple of hoses and plug one hole in the block.
I also changed the rear brake pads. That was a piece of cake.
Old 02-10-2019, 02:36 PM
  #53
Verybumpy's Avatar
Well done! Thanks for the pics. Turbos look in good shape, not much play in bearings I assume.
Old 05-06-2019, 05:35 PM
  #54
mutant9's Avatar
Just had my oil separator go this morning.. This repair is a major expense that was not on my radar. Just picked up the car at the end of March. I guess I was to focused on the turbo issues going around. Used the TSB to price check the dealer, the originally quoted me over $2400 for the job. Got it down to 1700.
I have a 15 a8l 4.0 w 69k miles
Old 05-20-2019, 02:01 PM
  #55
Kcampbel44145's Avatar
Default Squealing PCV Valve
Hello,
I’m not an expert on engine, especially not one as complicated/over-engineered as Audi’s so I need some help. I have 2015 A8L 4.0T with less than 50K miles. The engine started a terrible squealing sound last night. They told me it was the crankcase breather fault code and was $2,000 to repair.
1) Is this right and why wouldn’t it be covered under warranty?
2) Is it worth taking to a more affordable mechanic to get a second quote?
3) Is the vehicle safe to drive if I do try to get another quote?
THanks for your help!!
Kevin
Old 05-20-2019, 02:37 PM
  #56
mutant9's Avatar
When this happened on mine I called 2 independents and 2 audi dealers. Use the TSB for the required parts list and make the dealer match the parts costs on Audi parts USA. Com
The independents were more expensive for some reason
Old 05-20-2019, 03:16 PM
  #57
landjb4u's Avatar
Originally Posted by Kcampbel44145
Hello,
Kevin
When this happened to me I drove home about 9 miles total with the squeal going. Then had it towed to my mechanic for replacement. Around $1200 total.
Old 05-24-2019, 10:25 AM
  #58
andrewmr's Avatar
Anyone have more pictures and instruction on how to do this repair?
Old 05-25-2019, 09:58 AM
  #59
the_duke's Avatar
No clue if this is valid but it's worth a try.
Old 05-25-2019, 10:08 AM
  #60
mutant9's Avatar
Where did you find that? Any link to an actual audi Site? I need to get my $1800 refunded.
Quick Reply: Could REALLY use advice on PCV valve
