cylinder deactivation?
And it works seamlessly. The stop-start system; not so well. Turned it off the first day and have left it off.
My 4.2 regularly gets 29+ highway and around 18 city.
As calculated manually and by the bordcomputer.
I wonder if the mileage loss is due to higher RPM requirements on 4 cylinders...
The 4.2 with the 8 speed just coasts in comparison to what D3 did - typically 400-500 RPM less.
4-cylinder mode on the Audi V8TT improves mileage because the throttle has to be opened more in order to produce the power required to motivate the car. This reduces pumping losses, which are significant for a 4-stroke gasoline engine.
My S6 gets better mileage than my 2005 S4 Cab with the 4.2 V8, despite being heavier, larger and more powerful. Audi must be doing something right with this technology.
what is so wrong with the stop-start technology? Is it any more than a slight delay when stopped at a traffic light when you hit the gas? Are there other concerns/problems with it?
Just give it a try and tell us what you think. I thought it was a royal pain.
