D4 2014 a8L air spring/line fault after pothole hit
Hi. About a month ago I hit a pothole on a city street, on the front passenger side - pretty hard.
Later on the highway, I got the yellow air suspension fault, BUT the smooth ride continued (normally, when I get the yellow warning due to a sensor issue, it becomes a very rough ride).
Below are the codes - Address 34.
I've noticed this:
Thanks in advance,
Randy
I've noticed this:
- getting fault codes on both front drivers and passengers, but issue seems to be only on the passenger side
- the front passenger side ride height seems to be a bit lower than the driver's side
- no codes thrown in dynamic mode
- Yellow code thrown when 'comfort mode' mode is selected as the care raises a bit, but seems to still be sagging on the passenger side, albeit slightly
- during any yellow code, the ride smoothness doesn't 'shut off' e.g. not rough
- when I 'raise' the car in settings to its fullest height, it faults RED and the front passenger corner DOES NOT raise fully and you can hear hissing from in the passenger wheel well, I assume air leaking. If I move the selector back to dynamic, the car lowers and then a key cycle eliminates the fault light.
- suspension does not 'bottom out' overnight, etc. It does retain its height although I do feel the passenger front is lower than driver's side
- I have not used vcds to check anything but codes; concerned that I will get into ride height and render undrivable.
- I did jack car up on drivers side while in jack mode - passenger side depressed almost to wheel well itself so I stopped. The car did level out back to post-pot hole height.
- ride height sensors seem to be fine
Thanks in advance,
Randy
Code:
01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 3B-Sensor Elect. -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 48-Seat, Rear, DS -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 5B-Seat,Rear,PS -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 81-Gear Shift -- Status: OK 0000 85-On Board Cam. -- Status: OK 0000 88-Multicont. Seat Driver -- Status: OK 0000 89-Multicont. Seat Pass. -- Status: OK 0000 8A-Multicont. Seat Rear,DS -- Status: OK 0000 8B-Adaptive Cruise 2 -- Status: OK 0000 8D-Multicont. Seat Rear,PS -- Status: OK 0000 8E-Image Processing -- Status: Malfunction 0010 8F-Pretens. Frt Left -- Status: OK 0000 90-Pretens. Frt Right -- Status: OK 0000 BA-Motor Mounts -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (------CEUA) Labels:. 079-907-560-CFS2.clb Part No SW: 4H0 906 014 L HW: 4H0 906 014 Component: 4.0l V8TFSI / H62 0005 Revision: NCH62--- CVN: B4FF145D Coding: 022A00326546010E1000 Shop #: WSC 03621 002 1048576 ASAM Dataset: EV_ECM40TFS0114H0906014L 001005 ROD: EV_ECM40TFS0114H0906014L.rod VCID: 2C01042CB68F395AA3B-8078 VINID: 9D1962091594195780005089084CC1646B 5 Faults Found: 4007 - Idle Control System RPM P0507 00 [01100000] - Higher than Expected. Intermittent - Not Confirmed - Tested Since Memory Clear 8218 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2 P2098 00 [01101000] - Too Lean Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 2 Mileage: 334897 km Date: 2024.03.28 Time: 16:47:01 Engine RPM: 2178.50 /min Normed load value: 24.7 % Vehicle speed: 132 km/h Coolant temperature: 99 °C Intake air temperature: 25 °C Ambient air pressure: 980 mbar Voltage terminal 30: 14.182 V Unlearning counter according OBD: 39 Engine status: COENG_RUNNING Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3 7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1 P2096 00 [01101000] - Too Lean Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Mileage: 334780 km Date: 2024.03.27 Time: 20:43:55 Engine RPM: 2625.00 /min Normed load value: 23.9 % Vehicle speed: 106 km/h Coolant temperature: 87 °C Intake air temperature: 19 °C Ambient air pressure: 980 mbar Voltage terminal 30: 13.805 V Unlearning counter according OBD: 39 Engine status: COENG_RUNNING Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3 10203 - Random/Multiple Cylinder Misfire Detected P0300 00 [01100000] - - Intermittent - Not Confirmed - Tested Since Memory Clear 10594 - Cylinder 4 P0304 00 [01100000] - Misfire Detected Intermittent - Not Confirmed - Tested Since Memory Clear Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 4H1 927 158 EE HW: 0BK 927 156 AG Component: 0BK 40TFSIUSA H16 1002 Revision: --H16--- CVN: 22131AD3 Coding: 000001 Shop #: WSC 42355 001 1048576 ASAM Dataset: EV_TCMALX51011 002022 ROD: EV_TCMALX51011_002_AU64.rod VCID: 77ABEB403F494A821E9-8022 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb Part No SW: 4H0 907 379 E HW: 4H0 907 379 E Component: ESP PREMIUM H10 0352 Revision: -------- Serial number: -------------- Coding: C4E5F30023A7CF00E200 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ESPPremi 005013 ROD: EV_ESPPremi_005_AU64.rod VCID: 34311C4C6EBF619AFBB-8060 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 4H0 907 064 DD HW: 4H0 907 064 DD Component: BCM2 2.0 H35 0510 Revision: 00002001 Coding: 0DA72046000000000000 Shop #: WSC 02391 785 00200 VCID: 6E85CE2440930B4ACDF-803A Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C Component: J764 ELV MLB H40 0046 Serial number: 2313000129216014 No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels: None Part No SW: 4H0 959 760 E HW: 4H0 959 760 E Component: MEM-BFS H08 0156 Revision: AA000000 Serial number: 00000071706668 Coding: C018B60085047201010001010101112131313333283333 Shop #: WSC 42355 001 1048576 VCID: 3537214865457892CC5-8060 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb Part No SW: 4H0 820 043 L HW: 4H0 820 043 L Component: Klima 4 Zonen H20 0130 Coding: 688122FE7C Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiFront 001050 ROD: EV_AirCondiFront_001_AU64.rod VCID: 290FFD38B97D2C7258D-807C 2 Faults Found: 0073 - Motor for Right Footwell Flap B10BA 22 [00001001] - Signal Amplitude Too High Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 254 Reset counter: 247 Mileage: 330010 km Date: 2024.02.04 Time: 10:07:01 0137 - Motor for Right Side Window Defrost Flap B10D8 22 [00001001] - Signal Amplitude Too High Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 18 Reset counter: 247 Mileage: 335263 km Date: 2024.04.03 Time: 17:08:17 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb Part No SW: 4H0 907 063 CG HW: 4H0 907 063 Component: BCM1 2.0 H12 0130 Revision: 11012002 Serial number: 00000001607046 Coding: 09072091077C9FE38B000804A00038000098D2088E0001218001085C7B00 Shop #: WSC 02391 785 00200 VCID: 6FBBD32047990242C69-803A Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB Component: WWS641 130618 H35 0080 Serial number: 130710102404 Coding: 0045F7 Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10335621 Coding: 025523 Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B Component: E1 - LDS H07 0044 Serial number: 29 07 2013 00000631 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Serial number: 0000002274555R784T03 Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B Component: A31 LED Mod1L H03 0006 Serial number: 00000012081300010791 Coding: 100000 Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B Component: A27 LED Mod1R H03 0006 Serial number: 00000011051100010744 Coding: 100000 Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C Component: EVLS-SG H08 0300 Serial number: WA107413000004154092 Coding: 020300 Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 Serial number: E1B881C6000000000001 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG Component: PARKHILFE ACC H01 0083 Revision: 11001001 Serial number: 61031321102613 Coding: A80B0E Shop #: WSC 02391 785 00200 ASAM Dataset: EV_EPHVA18AU57X0000 004009 ROD: EV_EPHVA18AU57X0000_004.rod VCID: 71BFD558512D14B2D0D-8024 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb Part No SW: 4H0 907 561 B HW: 4H0 907 561 Component: ACC3 H19 0410 Serial number: 00000000000000 Dataset Number: 4H0909863D 0030 Coding: 7E01020101 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContrAU64X 002021 ROD: EV_AdaptCruisContrAU64X_002.rod VCID: 2A0D0234BC7B276A517-807E 4 Faults Found: 88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned C1103 00 [00001001] - - [FAULT_MAR_SLOW_MISALIGNMENT] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 32 Mileage: 330010 km Date: 2024.02.04 Time: 10:07:01 Control Module temperature: 13 °C Voltage terminal 15: 11.959 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned C1103 00 [00001001] - - [FAULT_MAR_FAST_MISALIGNMENT] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 32 Mileage: 330010 km Date: 2024.02.04 Time: 10:07:01 Control Module temperature: 13 °C Voltage terminal 15: 11.959 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned C1103 00 [00001001] - - [FAULT_MAR_PRE_MISALIGNMENT] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 254 Reset counter: 247 Mileage: 330010 km Date: 2024.02.04 Time: 10:07:01 Control Module temperature: 13 °C Voltage terminal 15: 11.959 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² 93440 - Function Restriction due to Faults in Other Modules U1113 00 [00001001] - - [FAULT_CIS_VIDEO_FAIL] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 254 Reset counter: 247 Mileage: 330010 km Date: 2024.02.04 Time: 10:07:01 Control Module temperature: 13 °C Voltage terminal 15: 12.025 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 4H0-959-655.clb Part No SW: 4H0 959 655 D HW: 4H0 959 655 D Component: Airbag10.43 H45 0042 Revision: -------- Serial number: 003JS001KU2H Dataset Number: 4H0909602D 0004 Coding: 303143303230303030314A55304C34483053 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirbaAU10BPAAU64X 001014 ROD: EV_AirbaAU10BPAAU64X_VW51.rod VCID: 372B2B407FC98A82DE9-8062 Seat occupied recognition: Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A Component: BF-Gewichtss. H03 0040 Serial number: 5850000R1362607CLQ Coding: 000000 Crash sensor for side airbag: driver side: Serial number: 3575HRB400C50IPGHGV4 Front Passenger's Side Airbag Crash Sensor: Serial number: 3585HRB400C50IPGH124 Rear Side Airbag Crash Sensor (on driver's side): Serial number: 3515JRB400A50L369GIY Passenger side rear thorax airbag crash sensor: Serial number: 3525JRB400A50L36798G Crash sensor for front airbag: driver side: Serial number: 3554VRB405T22HCSE9PI Crash sensor for front airbag: front passenger side: Serial number: 3564VRB405V22HCSD0PB No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb Part No SW: 4H0 953 568 H HW: 4H0 953 568 H Component: Lenks.Modul H04 0005 Revision: -------- Serial number: 90815MGK0000E Coding: 0004BC Shop #: WSC 02391 785 00200 VCID: 3829287C725785FAD73-806C Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L Component: E221 - MFL H09 0010 Serial number: 04 07 2013 B1183851 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1 Part No SW: 4H0 920 980 K HW: 4H0 920 980 K Component: TBenUSAACC--- H50 0515 Revision: 36081079 Serial number: 658080813592004 Coding: 0B4608015740D705020000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RBD4K 004046 ROD: EV_RBD4K_AU64.rod VCID: 33331F506BB166A2E21-8066 Analog_clock: Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G Component: Analoguhr D4 H05 0225 Serial number: 2130704016929 1 Fault Found: 9437188 - Fuel Tank Level Sensor 3; Insulation Resistance too Low B117B 1A [00001000] - Resistance Too Low Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 24 Mileage: 335615 km Date: 2024.04.05 Time: 15:33:29 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb Part No SW: 4H0 907 468 AC HW: 4H0 907 468 AC Component: J533--Gateway H12 0037 Revision: -------- Serial number: 00000001056988 Dataset Number: 4H0909515F 0071 Coding: 00E5074800 Shop #: WSC 02391 785 00200 GVL: FFAFE94CFAE3E3FCC100 ASAM Dataset: EV_GatewPkoUDS 001018 ROD: EV_GatewPkoUDS_001_AU57.rod VCID: 72BDDA54542B2FAA297-8026 Battery Monitoring Control Module: Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F Component: J367-BDM H08 0181 Serial number: 50206F53071911810394 Voltage stabilizer: Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C Component: J532_DCDCStab H05 0006 Serial number: 13204002861021200410 No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb Part No SW: 8K0 857 511 G HW: 8K0 857 511 G Component: FLA H04 0020 Revision: AB001001 Coding: 04018B6B74745D545420363E00 Shop #: WSC 02391 785 00200 VCID: 3537214865457892CC5-8060 No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb Part No SW: 4H0 919 158 L HW: 4H0 919 158 L Component: Klima Fond H16 0121 Coding: 2600000000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiHeck 001039 ROD: EV_AirCondiHeck_AU64.rod VCID: 392F2D7849DD9CF228D-806C No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control (J197) Labels:. 4G0-907-553.clb Part No SW: 4H0 907 553 E HW: 4H0 907 553 Component: LUFE-DAEMPFER H17 0099 Dataset Number: 4H0909553G 0036 Coding: 008002 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirSuspe 003024 ROD: EV_AirSuspe_VW51.rod VCID: 2E050E2480934B4A8DF-807A 2 Faults Found: 677392 - Air Spring or Air Line; Front Left C1147 07 [00001000] - Mechanical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 2 Reset counter: 24 Mileage: 335444 km Date: 2024.04.05 Time: 09:33:50 677393 - Air Spring or Air Line; Front Right C1148 07 [00001000] - Mechanical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 2 Reset counter: 24 Mileage: 335444 km Date: 2024.04.05 Time: 09:33:50 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4H0 959 760 E HW: 4H0 959 760 E Component: MEM-FS H08 0156 Revision: AA000000 Serial number: 00000071707233 Coding: C018BF8085857201030001010101112131313333203333 Shop #: WSC 42355 001 1048576 VCID: 3537214865457892CC5-8060 No fault code found. ------------------------------------------------------------------------------- Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb Part No SW: 4H0 907 637 K HW: 4H0 907 637 F Component: SARA 6D H02 0056 Revision: -------- Serial number: EJ1BPA77011BCX Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SARA2 005012 ROD: EV_SARA2.rod VCID: 372B2B407FC98A82DE9-8062 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: Redir Fail! Part No SW: 4H0 907 566 A HW: 4G0 907 566 Component: J769 SWA MasterH02 0050 Revision: 00H02000 Serial number: 6PZ 010 287-07 Coding: 0000002 Shop #: WSC 02391 785 00200 VCID: 2E050E248C134B4A8DF-807A Subsystem 1 - Part No: 4H0 907 568 A Component: J770 SWA Slave H02 0050 Subsystem 2 - Serial number: 6PZ 010 287-27 Subsystem 3 - Serial number: 5F27.07.1300H02000AMS15764ÿ Subsystem 4 - Serial number: S15764ÿ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb Part No SW: 4H0 959 793 R HW: 4H0 959 793 G Component: TSG FA H06 0273 Revision: -------- Serial number: 0000069421855 Coding: 011F1F005E0062C202003017 Shop #: WSC 02391 785 00200 VCID: 48C958BC02B7F57AA73-801C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb Part No SW: 4H0 907 064 DD HW: 4H0 907 064 DD Component: BCM2 2.0 H35 0510 Revision: 00002001 Serial number: 0312241485 Coding: 0106023A00FA759FB0B0C784020301070000000000000000000000000000 Shop #: WSC 02391 785 00200 VCID: 6E85CE2440930B4ACDF-803A Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719 Component: GTO BF H01 0080 Serial number: 00000000000000166424 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 4H4 959 591 HW: 4H4 959 591 Component: J245 007C H06 0005 Serial number: 329100082876 Coding: 020200 Subsystem 4 - Part No SW: 4H0 947 135 BR HW: 4H0 947 135 BR Component: Dachelektroni H13 0080 Serial number: A2013000000000725731 Coding: 070000 Subsystem 5 - Part No SW: 4H4 959 591 HW: 4H4 959 591 Component: J394 0014 H06 0005 Serial number: 329400084488 Coding: 020200 Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591 Component: J392 006A H06 0005 Serial number: 329100082874 Coding: 020200 Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591 Component: J867 00E0 H06 0005 Serial number: 329400084479 Coding: 020200 Subsystem 8 - Part No SW: 3AA 962 243 HW: 3AA 962 243 Component: GEB.F.Heckoef H12 0719 Serial number: 84378813 2 Faults Found: 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 32 Mileage: 330011 km Time Indication: 0 Date: 2024.02.04 Time: 10:12:24 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 32 Mileage: 330011 km Time Indication: 0 Date: 2024.02.04 Time: 10:13:37 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4G1 035 223 A HW: 4G1 035 223 A Component: BOSE-G3C7-ANC H02 0540 Revision: CJ002700 Serial number: 00000000001713 Coding: 030000 Shop #: WSC 02391 785 00200 VCID: 1C61D4ECE6AFC9DAD3B-8048 No fault code found. ------------------------------------------------------------------------------- Address 48: Seat, Rear, DS (J876) Labels: None Part No SW: 4H0 959 860 A HW: 4H0 959 860 A Component: MEM-FS-Fond H06 0158 Revision: AA000000 Serial number: 00000067704984 Coding: C01892808500700D0B00392038193A2039203B3B202020 Shop #: WSC 42355 001 1048576 VCID: 323D1A54942B6FAAE97-8066 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb Part No SW: 4H0 959 792 G HW: 4H0 959 792 G Component: TSG BF H06 0273 Revision: -------- Serial number: 0000066538297 Coding: 011F1F005E0062C202003006 Shop #: WSC 02391 785 00200 VCID: 3C21346C466FA9DA33B-8068 1 Fault Found: 00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 246 Mileage: 330010 km Time Indication: 0 Date: 2024.02.04 Time: 10:09:39 ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 F HW: 4H0 907 801 A Component: EPB-4 H03 0013 Revision: -------- Serial number: 00000000793300 Dataset Number: 4H0909522C 0011 ASAM Dataset: EV_ParkiBrake 001027 ROD: EV_ParkiBrake_VW51.rod VCID: 2B030730B3813E62AA1-807E No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb Part No SW: 4H0 035 082 G HW: 4H0 035 082 Component: Radio U SIRIU H60 0133 Revision: AB001007 Serial number: 155H10D7572906 Coding: 020007010000000001 Shop #: WSC 02391 785 00200 VCID: 2517F108D5E508127C5-8070 No fault code found. ------------------------------------------------------------------------------- Address 5B: Seat,Rear,PS (J877) Labels: None Part No SW: 4H0 959 860 A HW: 4H0 959 860 A Component: MEM-BFS-Fond H06 0158 Revision: AA000000 Serial number: 00000067705411 Coding: C01896808500700D0B00392038193A2039203B3B382020 Shop #: WSC 42355 001 1048576 VCID: 323D1A54942B6FAAE97-8066 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4H0 035 746 F HW: 4H0 035 746 F Component: H-BNT-NA H40 0735 Revision: -------- Serial number: 183H$0D7511934 Coding: 020200000001F9EF7D128B1E00000003140001000000000000 Shop #: WSC 02391 785 00200 VCID: 2B030730B3013E62AA1-807E Subsystem 1 - Part No: 8R0 060 884 BD Component: NAR 2013/2014 0802 Subsystem 2 - Part No SW: 4H0 919 604 G HW: 4H0 919 604 G Component: DU8 D4 SV NB H48 0021 Serial number: AUZ8ZDDC900N5M0 Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600 Component: E380 BDT D4 H09 0065 Serial number: 00000000125262 Subsystem 4 - Part No: 8R0 060 961 F Component: CD-Database 5298 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb Part No SW: 4H0 959 795 D HW: 4H0 959 795 D Component: TSG HL H06 0273 Revision: -------- Serial number: 0000069311174 Coding: 010F1F00420062C202003006 Shop #: WSC 02391 785 00200 VCID: 3C21346C466FA9DA33B-8068 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4H0 907 428 B HW: 7P6 907 441 D Component: TopView H05 0220 Revision: 11001001 Serial number: 82330JF0099700 Coding: 020A000001010000000102000000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_CamerSysteTopViewAUDI 007026 ROD: EV_CamerSysteTopViewAUDI_007.rod VCID: 2C01042CB68F395AA3B-8078 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (----) Labels:* None Part No SW: 4H0 959 107 AB HW: 4H0 959 107 M Component: HDSG-Modul H11 0043 Revision: 10011001 Serial number: 196300464 Dataset Number: 4H0909541E 0022 Coding: 0210044100 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DeckLidContrUnit 001032 ROD: EV_DeckLidContrUnit.rod VCID: 6E85CE2440130B4ACDF-803A No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II (J773) Labels:* None Part No SW: 4H0 907 412 HW: 4H0 907 412 Component: ALM H05 0004 Revision: -------- Serial number: 000000118360 Dataset Number: 4F0000000__ U001 Coding: 200000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_Ambie 001008 ROD: EV_Ambie.rod VCID: 6393AF109BD1B622521-8036 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb Part No SW: 4H0 959 795 D HW: 4H0 959 795 D Component: TSG HR H06 0273 Revision: -------- Serial number: 0000069311173 Coding: 010F1F00420062C202003006 Shop #: WSC 02391 785 00200 VCID: 3C21346C466FA9DA33B-8068 No fault code found. ------------------------------------------------------------------------------- Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb Part No SW: 4H1 927 731 A HW: 4H1 927 731 A Component: GSM-LL H08 0083 Revision: 0L0D5015 Serial number: SN130704 0329 ASAM Dataset: EV_GSM2x3Mono 001017 ROD: EV_GSM2x3Mono_AU64.rod VCID: 2B030730B3813E62AA1-807E No fault code found. ------------------------------------------------------------------------------- Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb Part No SW: 4G0 907 217 A HW: 4H0 907 217 A Component: DPC-SG H26 0038 Revision: -------- Serial number: 262130025421000 Dataset Number: 4H0909547E 0033 Coding: E9060000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_OnBoardCamerDPC 001007 ROD: EV_OnBoardCamerDPC.rod VCID: 2615F604A863030A75F-8072 No fault code found. ------------------------------------------------------------------------------- Address 88: Multicont. Seat Driver (J873) Labels:* None Part No SW: 4H0 907 182 H HW: 4H0 907 182 H Component: IVB H07 0042 Serial number: 00012398106701 Dataset Number: 4H0909880D 0019 Coding: 766FF2 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_IVBDriveSideFrnt 001003 ROD: EV_IVBDriveSideFrnt.rod VCID: 2F3B132087994242869-807A No fault code found. ------------------------------------------------------------------------------- Address 89: Multicont. Seat Pass. (J872) Labels:* None Part No SW: 4H0 907 182 H HW: 4H0 907 182 H Component: IVB H07 0042 Serial number: 00012398102601 Dataset Number: 4H0909881D 0019 Coding: 366FF2 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_IVBPasseSideFrnt 001003 ROD: EV_IVBDriveSideFrnt.rod VCID: 2F3B132087994242869-807A No fault code found. ------------------------------------------------------------------------------- Address 8A: Multicont. Seat Rear,DS (J875) Labels:* None Part No SW: 4H0 907 182 G HW: 4H0 907 182 G Component: IVB H08 0042 Serial number: 00012397008701 Dataset Number: 4H0909882D 0014 Coding: 306F00 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_IVBDriveSideRear 001003 ROD: EV_IVBDriveSideFrnt.rod VCID: 2E050E2480934B4A8DF-807A No fault code found. ------------------------------------------------------------------------------- Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb Part No SW: 4H0 907 541 B HW: 4H0 907 541 Component: ACC3 H19 0400 Serial number: 00000000000000 Coding: 7E01020101 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContr2AU64X 002018 ROD: EV_AdaptCruisContr2AU64X_002.rod VCID: 2809F83CA277157A473-807C No fault code found. ------------------------------------------------------------------------------- Address 8D: Multicont. Seat Rear,PS (J874) Labels:* None Part No SW: 4H0 907 182 G HW: 4H0 907 182 G Component: IVB H08 0042 Serial number: 00012397022301 Dataset Number: 4H0909883D 0014 Coding: 306F00 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_IVBPasseSideRear 001003 ROD: EV_IVBDriveSideFrnt.rod VCID: 2E050E2480934B4A8DF-807A No fault code found. ------------------------------------------------------------------------------- Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb Part No SW: 4G0 907 107 E HW: 4H0 907 107 Component: BV-SG H32 0041 Serial number: 005000122207137 Coding: 02A19A000111 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_BC7 001001 ROD: EV_BC7.rod VCID: 2809F83CA277157A473-807C 1 Fault Found: 0161 - Video Cable for Image Processing C1107 02 [00001001] - Signal Failure [No_camera_found_on_startup] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 254 Reset counter: 247 Mileage: 330018 km Date: 2024.02.04 Time: 17:34:00 Outside temperature: 12.0 °C Voltage terminal 15: 13.8 V Control Module temperature: 12.0 °C ------------------------------------------------------------------------------- Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 945 B HW: 4H0 980 945 C Component: RGS-VL H13 0080 Dataset Number: 4H0909614C 0003 Coding: 0066F609031F0376070308014240C2010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_L 002004 ROD: EV_RGS_L.rod VCID: 313F155891AD54B290D-8064 No fault code found. ------------------------------------------------------------------------------- Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 946 B HW: 4H0 980 946 C Component: RGS-VR H13 0080 Dataset Number: 4H0909615C 0003 Coding: 0066F609031F0376070308014240C2010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_R 002004 ROD: EV_RGS_R.rod VCID: 323D1A5494AB6FAAE97-8066 No fault code found. ------------------------------------------------------------------------------- Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb Part No SW: 4H0 907 145 HW: 4H0 907 145 Component: AEM - LEAR H07 0006 Revision: 00001001 Serial number: 97809002327300 Dataset Number: 4H0909578A 0011 ASAM Dataset: EV_AEMLearAU64X 002014 ROD: EV_AEMLearAU64X.rod VCID: 6695B60468E3C30AB5F-8032 1 Fault Found: 1294 - Actuator 1 for Drivetrain Mounts C1131 07 [00001001] - Mechanical Failure Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 1 Fault Frequency: 1 Reset counter: 32 Mileage: 330010 km Date: 2024.02.04 Time: 10:07:04 End----------(Elapsed Time: 03:28, VBatt start/end: 12.2V/12.2V)-----------
2018A5Coupe
07-23-2022 05:46 AM
boneyxy
Audi A5 / S5 / RS 5 Coupe & Cabrio
11-30-2020 02:25 PM
