help with vcds scan
help with vcds scan
2 Faults Found:
9057 - Turbocharger Speed Sensor 1
P2578 00 [108] - Electrical Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 93
Mileage: 168890 km
Date: 2019.07.12
Time: 11:56:42
Engine speed: 2661.50 /min
Normed load value: 44.7 %
Vehicle speed: 48 km/h
Coolant temperature: 59 °C
Intake air temperature: 27 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.900 V
Unlearning counter according OBD: 40
Crankshaft speed (RPM): 2429.0 /min
Vehicle speed: 57.47 km/h
AFS r Norm B1 mp: 0.9883
Actual charge pressure: 2498 hPa
Ambient air pressure: 1007 hPa
Mean injection quantity: 51.42 mg/stroke
Coolant temperature: 59.5 °C
9063 - Turbocharger Speed Sensor 1
P2580 00 [109] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Mileage: 168942 km
Date: 2019.07.12
Time: 21:44:10
Engine speed: 1772.00 /min
Normed load value: 61.2 %
Vehicle speed: 57 km/h
Coolant temperature: 85 °C
Intake air temperature: 25 °C
Voltage terminal 30: 13.180 V
Unlearning counter according OBD: 39
Crankshaft speed (RPM): 2359.0 /min
Vehicle speed: 59.26 km/h
AFS r Norm B1 mp: 1.0057
Actual charge pressure: 1453 hPa
Ambient air pressure: 1010 hPa
Mean injection quantity: 18.56 mg/stroke
Coolant temperature: 87.9 °C
1 Fault Found:
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 20
Mileage: 169075 km
Date: 2019.07.16
Time: 12:30:17
1 Fault Found:
0679 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 39
Reset counter: 240
Mileage: 168879 km
Date: 2019.07.10
Time: 16:04:16
VzRef: 00
Bit Info 1: 00
Bit Info 2: 47
Bit Info 3: 22
Bit Info 4: 00
F-Path: 2A
F-Type: 2E
Uz: B4
3 Faults Found:
03285 - Sensor for Contact with Door Handle; Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 168883 km
Time Indication: 0
Date: 2019.07.11
Time: 19:05:37
00192 - Rear Left Door Handle Touch Sensor (G417)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 168883 km
Time Indication: 0
Date: 2019.07.11
Time: 19:05:37
00193 - Rear Right Door Handle Touch Sensor (G418)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 168883 km
Time Indication: 0
Date: 2019.07.11
Time: 19:05:37
1 Fault Found:
0138 - Motor for Right Side Window Defrost Flap
B10D8 21 [009] - Signal Amplitude Too Low
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 240
Mileage: 168888 km
Date: 2019.07.12
Time: 11:14:48
3 Faults Found:
0280 - Oil Pressure and Temperature Sensor
C1004 FF [136] - Oil Press. implausible Correlation with Sensor 2
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 51
Reset counter: 235
Mileage: 167599 km
Date: 2019.06.14
Time: 14:13:08
0024 - Oil Pressure and Temperature Sensor
C1004 31 [136] - No Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 52
Reset counter: 235
Mileage: 167599 km
Date: 2019.06.14
Time: 14:13:08
0023 - Oil Pressure and Temperature Sensor
C1004 01 [136] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 238
Mileage: 167768 km
Date: 2019.06.21
Time: 17:26:22
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 5
Reset counter: 25
Mileage: 169139 km
Time Indication: 0
Date: 2019.07.19
Time: 10:12:35
Freeze Frame:
Bin. Bits: 00000001 00000000
Bin. Bits: 00000000 00000000
01043 - Control Module; Incorrect Software Version
Freeze Frame:
Fault Priority: 5
Fault Frequency: 230
Reset counter: 25
Mileage: 169139 km
Time Indication: 0
Date: 2019.07.19
Time: 10:18:55
Freeze Frame:
any help on anything would be a great help thanks
Freeze Frame:
Fault Priority: 2
Fault Frequency: 93
Mileage: 168890 km
Date: 2019.07.12
Time: 11:56:42
Freeze Frame:
Fault Priority: 2
Mileage: 168942 km
Date: 2019.07.12
Time: 21:44:10
1 Fault Found:
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 20
Mileage: 169075 km
Date: 2019.07.16
Time: 12:30:17
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 39
Reset counter: 240
Mileage: 168879 km
Date: 2019.07.10
Time: 16:04:16
VzRef: 00
Bit Info 1: 00
Bit Info 2: 47
Bit Info 3: 22
Bit Info 4: 00
F-Path: 2A
F-Type: 2E
Uz: B4
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 168883 km
Time Indication: 0
Date: 2019.07.11
Time: 19:05:37
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 168883 km
Time Indication: 0
Date: 2019.07.11
Time: 19:05:37
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 168883 km
Time Indication: 0
Date: 2019.07.11
Time: 19:05:37
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 240
Mileage: 168888 km
Date: 2019.07.12
Time: 11:14:48
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 51
Reset counter: 235
Mileage: 167599 km
Date: 2019.06.14
Time: 14:13:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 52
Reset counter: 235
Mileage: 167599 km
Date: 2019.06.14
Time: 14:13:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 238
Mileage: 167768 km
Date: 2019.06.21
Time: 17:26:22
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 25
Mileage: 169139 km
Time Indication: 0
Date: 2019.07.19
Time: 10:12:35
Freeze Frame:
Freeze Frame:
Fault Priority: 5
Reset counter: 25
Mileage: 169139 km
Time Indication: 0
Date: 2019.07.19
Time: 10:18:55
Freeze Frame:
Younger
04-30-2008 08:22 AM
omega919
04-10-2007 09:41 PM
LCP
12
01-17-2000 07:17 PM
